What else before the LS1 drops in?
Car: 1992 Jade Green---Trans Am Converti
Ok, here's my list so far.. Anything I'm missing that's best to do *before* the engine is in a bay?
LS6 intake
LS6 PCV system
LS6 oil pump
Better timing chain
Cheater cam kit
ported TB and bumpstop mod
ported MAF ends
Anything else easy to do now (and cheap, I'm running out of money!!)??
Thanks,
Kevin D.
LS6 intake
LS6 PCV system
LS6 oil pump
Better timing chain
Cheater cam kit
ported MAF ends
Thanks,
Kevin D.
Car: 1991 RS
Is their a differenct between the ls1 and ls6 oil pumps?
Before i put my motor in i plan on replacing it, and on gmpartsdirect the same pump shows up for all aplications.
Car: 1991 Camaro
2001-02 the LS1's got the LS6 pump, if you have the old LS1 model just upgrade to a ported pump like from texas speed or somwhere like that.
Your looking pretty good, might want to upgrade your rod bolts to some arp or katech cause thats your weakest link for the bottom end. If you have a 2000 or older engine then i would defintaly do it since in 01 they addresed the issue and put in some better ones.
Justin
Justin
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
melling also has a high pressure/high volume pump that i got from advanced racing dynamics for around 90 bux
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
dont forget about the car...
nows the time to clean up in the engine bay, fill holes, paint, re-route lines, move wires or whatever...
It's the modified LS6 pump from Thunder, so I think I'm set. How much are the rod bolts and how much trouble? Not looking to raise the engine up higher than my roller, but will if it's cheap enough I'll do it.
As far as the car, everything's ripped out, all the 4th gen wiring is in, the bay is cleaned, all un-needed stuff is removed. I would paint it now, but if I did I would fill everything hole not used, reshape the inner fenders, and a lot of detailing. Not something I'm looking to go through right now, it will have to wait until the next time the engine is out.
Thanks!
Kevin D.
Thanks!
Kevin D.
RedLeader289
May 28, 2019 01:47 PM
86White_T/A305
Sep 21, 2015 05:28 PM
