LS1 Fuel layout?
Old Dec 17, 2005 | 07:06 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
LS1 Fuel layout?
Ok im using the 4th gen tank, with the in-tank pump and regulator. Will this layout work? and can i just use my stock Fuel lines? One would be the feed line and the other the pressure line or whatever its called
Old Dec 18, 2005 | 01:02 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
i would like to know as well
Old Dec 18, 2005 | 01:37 AM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
I used the 4th gen tank
the 4th gen lines will bolt into the third gen downline... the fuel filter will fit but it will be in a cockeyed position, not the stock one so you will have to rig something up
It just needs one line to go down as its a returnless system
I then took the 3rd gen return line and used it for the 4th gen evap line.. just some hose and clamps..
golden..
the 4th gen lines down the car will not work, they got some wack *** bends in them
Old Dec 18, 2005 | 05:05 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
do you have any pictures showing how you rigged it up? so what part do i need to connect my stock lines to the tank lines(there the quick disconnect ones)?
Old Dec 18, 2005 | 10:15 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Axle/Gears: 4.11s
pictures would be ideal.. i havent seen my car in like 6 months tho so i'll try to explain it a little bit better
heres what the stock look is
here the fuel filter is east to west on the car.. with the line hooking into it and out
i cant for the life of me find a pic of the 4th gen lines..
there are three plastic lines coming from the fuel tank
feed.. return..evap/purge
there is only two lines down the body tho.. but you cant use them cause they have some wicked hooks at the end,ive laid them out on the ground and its not even close...
ok.. from there you will have the three plastic lines..
the feed line clips into the fuel filter which then goes to a hardline that goes into a metal T.. the return line also connects from a quick connect to a hardline then into this T... and like a glove the 3rd gen feed line will connect into that T as well
now you will have the purge line as a quick connect fitting, the plastic one.. i just hacked the line for the evap off the 4th gen lines pluged it in.. I then chopped the line going to the stock 3rd gen return in about the same area.. some 1/4" hose and two clamps and it is now my purge feed for the front
im pretty sure I used the ls1 filter bracket and it mounted to the frame and tied all the lines up nicely.. the filter runs north/south unlike the stock 3rd gen
i'll be home at x-mas and if it was good it still might be in the garage and I'll snap some pictures of it
Old Dec 19, 2005 | 12:01 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Yes Please more pics. This is very helpfull tips. I need to do all the lines- Feed, Return, EVAP. CALIFORNIA RULES SUCK!!
Old Dec 19, 2005 | 09:07 AM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
yea more pictures would be awsome..im getting the idea though. My 2000 Plastic tank only has 2 plastic lines coming out from it? does this change the setup compared to yours?
Old Dec 19, 2005 | 09:37 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Axle/Gears: 4.11s
maybe the third line was a metal return line.. there should be three lines tho unless you didnt get the evap stuff..
did you get anything from the 4th gen lines.. you will have to track down the T and all that if you dont have it
Old Dec 20, 2005 | 12:30 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
do you have a picture of what the T should look like. When i get the engine im going to take all the stuff i need.
Old Jan 4, 2006 | 04:45 PM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
Axle/Gears: soon to be 3.73's
this would be nice. I am gong to be doing the swap and need to know how to run the lines. I also live in cali and i need verything to be smog legal. Does this mean i have to do a gas tank swap also?
Old Jan 7, 2006 | 08:27 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Anyone figure out the fuel gauge issue on this swap? As in did you manage to get your stock gauge to work properly off the ls1 sending unit?
Old Jan 7, 2006 | 01:52 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Im using the 4th gen interoir and gauges so i woudlnt know exactly how to
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
NBrehm
Aug 25, 2015 11:49 PM
hayesaw0210
Aug 23, 2015 11:15 PM
