Fuel pump wiring
Old Jan 7, 2006 | 03:31 PM
mliers's Avatar
Car: 1992 Camaro
Transmission: Auto :(
Axle/Gears: 94 Formula rear end with 3.42s
Fuel pump wiring
Fuel pump isnt turning on but when I give power to the test connector it does turn on so I'm guessing the grey wire from the relay isn't hooked up right. It goes into the c100 correct? If someone can tell me where it goes thatd be very helpful, thanks.
Old Jan 7, 2006 | 06:47 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
From the C100 connector, it goes to the double plugs under the passenger side kick panel toward the back of the car and goes out under the backseat.
Old Jan 8, 2006 | 11:19 AM
LT1powered89's Avatar
Car: 1989 Chevrolet Camaro
Axle/Gears: 2000 rear, 3.73, auburn locker
I soldered the grey wire from the painless into the factory fuel pump wire. I think it's grey too. I think the conector is on the bottom of the car in front of the tank. It's not hard to get to. there where only three wires on mine. Don't cut the old wire out or it won't work, mine didn't when I cut it so I soldered them back together.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
