My LS1 / T56 swap - motor in
Howdy,
I love this forum, it has been very helpful for me. I've been taking a lot of pics and will have a write-up on my site when i get done. Here's a couple of the motor going in:
Used Spohn motor mounts, t56 trans mount, plus spohn rear suspension pieces. New bushings, ball joints, koni shocks, etc. USing 4th gen clutch pedal, 4th gen gas tank. Painted the engine bay while it was apart. More pics as the work goes by, but having the motor in is always a nice milestone.
Thanks for the great info guys
James
James
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Looking good bro. Keep posting pics cause im about to do my swap. Good luck dude
i pieced together the parts from several people.
I took photos of the crossmember notch, pedals, gas tank, and other misc which i will post in a few weeks when everything is done.
Thanks, guys
Thanks, guys
Car: 1991 RS
Looks great man
. I could only imagine what its like seeing that engine in the car for the first time. Definatly keep us all updated.
I'm working on getting the 4th gen gas tank in my car too. The salvage yard i got the tank from decided to cut all the plastic piping that connects to the sending unit, so that might be a set back unless i can buy it new from gm.
Car: Camaro RS/SS
Engine: 5.7 LS1
Hey Z28Evans if you could post some pics of that, that would be AWSOME cause im in the same place as Camaro0605. Thanks alot
Joey
Joey
Ask and you shall recieve:
I'll post some photos from under the car and engine bay soon, i used the stock line and filter assembly, other photos will make more sense. Once i figure out how to change the signal from the ls1 fuel level sender to the factory range i'll post it up as well.
If anyone has some comments or things for me to add let me know,
Thanks,
James
Thanks,
James
Car: Camaro RS/SS
Engine: 5.7 LS1
hey thank alot for the great pic, this is really going to help me out for the swap (AWESOME!!!) So you got the quick connects from a autostore and did you make your own lines going to the pump?
Car: Camaro RS/SS
Engine: 5.7 LS1
Also check out this pic of my fuel tank. I made some notes could you make sure its correct.
Car: Camaro RS/SS
Engine: 5.7 LS1
Also check this out. I made it on Paint (looks pretty good)
Is this right for the LS1 setup? Sorry for the pics just wanna be really sure before i do this.
Is this right for the LS1 setup? Sorry for the pics just wanna be really sure before i do this. Howdy,
It looks like you have it right, i'm not using the evap though (i don't live in CA)
Summit, jegs, and a few others sell quick connects that go to AN fittings, butthey were on back order. I bought autostore quick connects (3/8") , cut the barb off and used a 3/8 compression union to go to 3/8 hardline - and then connected them to the other 3/8 harlines to the fuel pump and one i made to the T.
I'll tryo to post pics in a few days.
Good luck.
James
Good luck.
James
Car: Camaro RS/SS
Engine: 5.7 LS1
Originally posted by z28evans
Howdy,
Howdy,
Joey
NBrehm
Aug 25, 2015 11:49 PM
