LS1 fuel tank (Plastic 99-02 style)
Old Jan 1, 2012 | 12:13 AM
  #101
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by 82Camaroguy
Yes, the 4th gen tank will work with the 5.0. LS1's typically use higher fuel pressure, so the pump in the 4th gen tank will have a higher output, however your regulator on the 5.0 should take care of it. The only other issue I see would be the vent and return lines that your IROC uses. The 4th gen tank has an self contained charcoal canister and I dont think it has a return line. If your in an area where emissions testing is important these might be things to consider as well.
The 4th gen f-body LS1 tank uses a return (they all do).
The 5.0 reg won't "take care of it", because the plastic 4th gen f-body LS1 tank has the reg built into the return, and so will keep pressure higher than the 5.0 reg set pressure.
Old Jan 1, 2012 | 09:26 AM
  #102
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: LS1 fuel tank (Plastic 99-02 style)
The reg is very easy to remove with just a screwdriver
Old Jan 2, 2012 | 01:07 AM
  #103
five7kid's Avatar
Yes, but that wasn't stated.
Old Jan 2, 2012 | 11:26 PM
  #104
penguinpanda0's Avatar
Car: 1987 IROC-Z Camaro
Engine: 305 LB9
And as for the aforementioned charcoal canister issues...? (Sorry n00b here..)
And I definitely will have to get new lines correct?
Old Jan 2, 2012 | 11:29 PM
  #105
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
new lines, you can use your thirdgen ones and slice them together unless youd like to make your own lines front to back. the charcoal canister is that ugly thing that barely worked on the inside of a thirdgens engine bay. most people delete them but a 4th gen has one built in. not necessary to remove them in fact they help for emissions and all that IIRC
Old Jan 3, 2012 | 11:07 AM
  #106
82Camaroguy's Avatar
Car: 1982 Z28
Transmission: 4l60
Thanks for the correction five7kid! I just got my plastic 4th gen tank and lines over the weekend and your correct, they do have a return line, also great point on the regulator, I forgot that the tank is internally regulated on the return side.
Old Jan 4, 2012 | 09:16 PM
  #107
88blackiroc's Avatar
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Originally Posted by shr00m
98 had metal, maybe 99 too. 00-02 definitely had plastic. Get the plastic lines and the metal fuel T and fuel filter. These will swap right in and your stock metal line will thread right in. Then all you need is some hose and clamps for EVAP.
Kevin D.
99 was plastic to
Old Jan 17, 2012 | 08:52 PM
  #108
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Originally Posted by kthxbai
(1)Fuel Sender Assembly
(2) Hose (EVAP Canister to Vent Solenoid)
(3) EVAP Vent Valve
(4) Fuel Tank Harness
(5) EVAP Canister
(6) Fuel Tank
(7) Overpressure Relief Valve
(8) Fuel Tank Pressure Sensor
just found this and i think it will be helpful to anyone trying to think through their plastic tank evap setup
Bringing this back up. #7 would connect to our white check valve thats down on the brake line bracket correct?
Old Jan 18, 2012 | 02:27 PM
  #109
five7kid's Avatar
No need for the white check valve.
Old Jan 18, 2012 | 04:30 PM
  #110
Dale's Avatar
Engine: 350 S-TPI
So there are 4 lines...
Send
Return
Line off item 5 goes to engine vac source correct?
What about line off item 7?
Old Jan 18, 2012 | 04:51 PM
  #111
five7kid's Avatar
The one coming off of the EVAP canister with a QD on it but no number goes to a solenoid on the engine.
Nothing is attached to #7. It just hangs out.
Old Jan 18, 2012 | 07:32 PM
  #112
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
#7 is the pressure relief incase the tank starts to build too much pressure
Old Jan 18, 2012 | 09:08 PM
  #113
Dale's Avatar
Engine: 350 S-TPI
Ok, on an LS engine, it goes to a solenoid, but for TPI it would just go to a vac source then.
#7 just hangs. oh, I thought my hose was cut and it went to something.
Thanks, I think I have this figured out now.
Old Jan 21, 2012 | 08:29 PM
  #114
Engine: 305 LB9
For a TPI I have to get a vacuum line for EVAP? And connect where?
Old Jan 21, 2012 | 10:03 PM
  #115
irocdls1's Avatar
Car: 88 Iroc ls1 swap
Engine: ls1
Transmission: 4l60e
Axle/Gears: original disc
All of this sounds like alot of work and complicating..... woundnt it be easier and give the same performance putting a gss340 pump and a fuel pressure regulater even though its a little pricey for the regulater....!!!!!!!!!!!!! sorry just want know cause im going that route
Old Jan 22, 2012 | 08:24 AM
  #116
Dale's Avatar
Engine: 350 S-TPI
Penguin, You dont have to put it to a vac source. But I dont like the smell of gas fumes, so I'm connecting to a vac source to burn the fumes. Lots of others let it go to nothing.
Iroc. Your talking about a pump.
Old Jan 28, 2012 | 09:16 PM
  #117
Zipacna's Avatar
Car: 1988 Camaro IROC T-Top
Engine: 350ci TPI
Transmission: TH-350
Axle/Gears: 4.11 Posi
I assume you have to run some sort of vac back there to control the pressure regulator?
Old Jan 29, 2012 | 08:03 AM
  #118
mwfrels's Avatar
Car: '86 Z28
Engine: SDPC TPI 350
Transmission: WC T5
Axle/Gears: 3.23 posi
LS1 regulator design does not use idle high vacuum unload. I know TPI cars used it but the LS1 regulator is pure spring pressure. Fuel pressure is constant regardless of throttle position.
M
Old Feb 3, 2012 | 02:49 PM
  #119
513camarors91's Avatar
Car: 91 camaro rs
Engine: ls6
Transmission: mn12
Axle/Gears: s60 3.73
i currently have a 305 tbi in my car now...my plans are to remove complete fuel system and make it out of aluminum 3/8 line and run a 4th gen fuel filter. no if i run the 4th gen filter would i have to do any thing to the fuel regulater that is in the stock pump. correct me if im wrong but the only time you have to remove it is wen ur going to use the vette filter?and i already have the 4th gen tank and the new fuel sending unit ready for intall
Old Feb 3, 2012 | 03:42 PM
  #120
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
correct, the vette filter has a built in regulator
Old Feb 4, 2012 | 12:28 AM
  #121
five7kid's Avatar
There is no reason to run a Vette filter with the LS1 plastic tank.
3rd gen EFI filter, 3/8" aluminum tubing, LS1 plastic tank:
Old Feb 7, 2012 | 03:55 PM
  #122
Strategicsalvag's Avatar
Using the setup shown above, what causes pressure to be built up in the fuel line to the fuel rail (engine)? Seems to me that if there is no restriction, the flow would be through the filter and immediately return to the tank via the return line. Very little flow and virtually no pressure would be available to the fuel rail......
Just curious.
Old Feb 7, 2012 | 04:24 PM
  #123
Sorry, just remembered the fuel pressure regulator is in the RETURN side of the sending unit on the LS1. That is what causes the buildup of pressure to the fuel rail.
In my best Emily Litella impression - "Never mind"........
Old Feb 8, 2012 | 12:13 AM
  #124
Zipacna's Avatar
Engine: 350ci TPI
If you look back through the thread there's actually one disassembled.
Old Apr 8, 2012 | 07:22 PM
  #125
Engine: 305 LB9
Originally Posted by 87IROC350
I'm looking to do the same thing .... using a plastic tank on my 3rd gen 5.0. Anyone done this before and is there any documentation on matching up the wiring?
This. I'm at a loss when it comes to wiring the thing.
Old Apr 8, 2012 | 09:33 PM
  #126
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
Axle/Gears: 10 bolt auburn pro posi, 4.10 gears
Wiring is fairly simple. Gray wire is fuel pump feed wire. Black wire is ground and purple is level sensor wire.
Old Apr 14, 2012 | 03:28 PM
  #127
Engine: 305 LB9
I know almost nothing about electrical, but it seems disconcerting that only three wires run to the stock pump while there are around eight running to the LS1 pump. I can still just cut the connectors and splice the three from the old connector to the three of matching color and just ignore the rest and it will work?
Old Apr 14, 2012 | 03:32 PM
  #128
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
You're thinking of the main bulkhead connector that also has wires for the purge solenoid and such. The LS pump setup is almost the exact same number of wires, you just need to add a ground since the tank is not metal.
Old Apr 14, 2012 | 03:39 PM
  #129
Engine: 305 LB9
EDIT: I think I understand, the black wire with the white stripe is ground, the rest are the same. Sorry to inconvenience you guys.
Old Sep 19, 2012 | 05:11 PM
  #130
92camaro_man's Avatar
do you have to run new fuel lines to use the ls1 tank for my 305 tbi. It there any way to use my stock lines?
Old Sep 19, 2012 | 05:25 PM
  #131
Dale's Avatar
Engine: 350 S-TPI
The hard lines under the car can be the same. But you will need to get adapters for the tank end, the line end, then run an "AN" line in between.
Old Sep 19, 2012 | 09:36 PM
  #132
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
run an or go cheap and do rubber hose, not suggested but if you rally need to drive the car itd be a temporary fix.
Old Sep 23, 2012 | 09:12 AM
  #133
could a v6 gas tank work? I just want a plastic tank.
Old Sep 23, 2012 | 11:12 AM
  #134
Zipacna's Avatar
Engine: 350ci TPI
Yes I found a v6 tank and a used a v8 sending unit because I needed the higher pressure pump. The tanks are the same 99-02 v6/v8 afaik
Old Sep 23, 2012 | 11:14 AM
  #135
cam-'s Avatar
Car: Camaro
Engine: 6.2L
V6 tank is the same and so far as I know the pump is also the same. I can tell you this much its strong enough to run a head/cam LS1 for 3 years lol. Theres no internal reg on the V6 tank though so use the vette filter and you'll be fine
Old Oct 19, 2012 | 06:12 PM
  #136
Sorry to be a bother but im still a little confused.
1) I have a 92 TBI
2) 1999 v6 plastic tank
3) have all plastic lines leaving the sending unit
?: where to buy the "T" bracket ?
?: Do i order the ls1 fuel sending unit from hawksthirdgen?
?: Will i have to remove the regulator off the ls1 sending unit?
?: Could i just change the pump to get more pressure and keep the stock sending unit, or does the pump not separate?
?: What about the an line? how do I know which ones or sizes to get, or how the connector pieces fit?
Please let me know or give me a number where i could call you and hear word for word instruction.
Old Oct 19, 2012 | 06:43 PM
  #137
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
help section at auto parts strore
not necessary just use the stock v6 unit
if you have the v6 sending unit i believe it should work
ur running tbi you dont need more pressure. youll need a regulator with the v6 pump probably as an ls1 would be overkill for tbi id think.
Old Nov 26, 2012 | 10:06 AM
  #138
On Friday, November 23, 2012. I completed my 4th gen gas tank swap.
Parts Used:
1) 1999 V6 Camaro Plastic Tanks (I pulled it myself so I had all the plastic lines connected to the sending unit)
2) 1992 305 TBI Engine
I did not worry about the gas gauge because it did not work before I made the swap. (I always travel with a 5 gal tank of gas filled. Plus when you drive your car to the point were it runs out of gas, you have a feel to when your car is about to run out) Sure enough my old tank was cracked around the solder, fuel neck and tank. (GM claimed there was no leak).
The car ran fine, used the 1999 camaro fuel filter. I connected the metal lines from the plastic tank to the metal lines of the car with a rubber hose. (This is what was on the car when I removed the old tank so I just used it to make my job easier. I was going to flare the lines using a double end flaring tool but I changed my mind.)
I must say I am satisfied with the results. I filled the tank up to the neck, and drove from Lakeland/Brandon/Tampa/ FL to Tallahassee FL on one tank of gas. (It use to take me two to three tanks with the old tank.)
Sorry I did not take pics of my process, however I am more than will to lead you through the steps to get the job done.
Thanks to everyone on this site who helped me in any way with performing this task.
Old Nov 26, 2012 | 03:50 PM
  #139
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
I am currious about one thing that I don't see here. On the 99 ls1 pump there are 4 wires going to the pump. The Orange W/Black stripe is a LO Reference wire, Are we not doing anything with this wire? I would guess this would be the ground for the sender??
Old Nov 26, 2012 | 09:15 PM
  #140
Car: 91 z28
Transmission: 4L60e
post #92
Old Nov 27, 2012 | 08:26 AM
  #141
jazzdadss's Avatar
Car: 1989 IROC LSX
Transmission: 4L65E
Thanks, sadly I have not been able to open any links on this site for a week or so, Including that link to the pin out...???
Old Nov 27, 2012 | 12:45 PM
  #142
mwfrels's Avatar
Car: '86 Z28
Transmission: WC T5
I can't open the link in post# 92 either...
M
Old Nov 30, 2012 | 01:12 PM
  #143
jazzdadss's Avatar
Car: 1989 IROC LSX
Transmission: 4L65E
Thank you for fixing the link!
Old Nov 30, 2012 | 06:39 PM
  #144
mwfrels's Avatar
Car: '86 Z28
Transmission: WC T5
Ditto...
M
Old Apr 21, 2013 | 12:34 AM
  #145
Engine: 305 LB9
Anybody ever gotten evap to work yet?
Old Aug 31, 2013 | 08:17 AM
  #146
cam-'s Avatar
Car: Camaro
Engine: 6.2L
^Not that Im aware of.
In other news a bit of an update worth sticking in here. The original Russel fuel rail adapter fitting shown on the left side here;
has been known to randomly BLOW OFF thus spraying fuel everywhere so anyone who has one should upgrade to the new version that has no plastic clip shown on the right. Also I might as well add that the stock metal clip style retainer clips ( see attached pic below ) work great and have no issues. Obviously not for all purposes as boosted guys need mo bigger lines but these are proven durable and support most NA applications. Be careful with fuel.....
Old Aug 31, 2013 | 11:44 PM
  #147
Car: 91 z28
Transmission: 4L60e
Someone on the boards did. His name escapes me. He was from Cali and iirc he built two cars, one for him and one for a family member. Both with fully functioning emissions.
Old Sep 1, 2013 | 05:21 AM
  #148
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
The shop doing the LS1 swap on my car is hooking up the evap I believe. Do you have any certain questions you need answered?
Old Sep 2, 2013 | 08:30 AM
  #149
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
You can have evap work perfect. But you need to use the ls1 gauge cluster if you want a fuel gauge. Ls1 pcm sends fuel level as serial data...which also contains information for the evap system to function. If you try to hook up a traditional style fuel gauge that sends a reference voltage to the sender, you HAVE to sever the connection to the pcm and it botches the whole works. Note:4th Gen guys that run traditional fuel level gauges disable evap in the process. (Simplified short explanation)
You cant trick it like other systems with resistors, because the level and pressure in the tank is constantly changing. Even if you fool it into venting like its half full, it won't be working "properly" the other 99% of the time.
If your shop gets it to work without the ls cluster, without mounting another sender in the tank, and using all 4th Gen parts you GOTTA post up!! I'de love to hook evap back up.
J.
Old Jan 15, 2014 | 06:04 PM
  #150
Engine: 305 LB9
As far as evap... I'm using the plastic tank with a 305 tpi engine. I never ran a vacuum line to the tank for emissions. Now I'm doing my egr system, and I notice that the egr solenoid is supposed to connect to the old charcoal canister that I no longer have. My goal is to have a functioning egr system and a functioning evap system so that I can hopefully pass CA smog. How would I route my vacuum lines to do this?
