progress stage 1
Old Feb 26, 2006 | 04:36 PM
xomega's Avatar
Car: 1990 chevy camaro rs
Engine: lt1
Transmission: 4l60e
Axle/Gears: 273:(
progress stage 1
installation of the lt1 begins at 10am. engine mounted and tranny bolted up all intact in the car by. 5. im exhausted.... now im looking to buy some headers. and i have a bunch of wiring to do. and need to drop the tank for the pump. whats the estimated work time on dropping/installing the tank?
Old Feb 26, 2006 | 05:01 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
If it's your first time, estimate 3-4 hours to get the tank out and 8-10 to get the stupid thing back in.
It's not too bad, just go ahead and take everything out. Remove the tires (at least the passenger) and get the rear as low as possible.
Kevin D.
Old Feb 26, 2006 | 07:09 PM
Firebat's Avatar
I take the rear completly out when droping the tank.
Old Mar 1, 2006 | 05:36 PM
STRIFE69's Avatar
Car: 91 camaro
Engine: 305TBI
Transmission: 5 speed
When I changed my fuel pump I dropped the rear with only leaving the LCA's on. Makes it easier for for bolting up the rear after you get the pump installed. Just make sure you get car up high enough cause the fill tube on the tank gonna need some space.
Be safe and good luck!
Drone358
Dec 10, 2015 08:16 PM
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
