LT1 wiring in a 3rd gen
Old Feb 27, 2006 | 12:39 AM
TA88GTA's Avatar
Got the LT1 in the car and having some issues, here is what the car is doing. Fires but only on a few cylinders, mainly #2 and #6 headers are getting really hot really fast and the rest don't seem to be making any heat. Engine sounds like it could honestly be running on 2 cylinders it runs so poorly. We have tested injectors and spark and it is present in every cylinder. Now for a few questions.
1) Is there a way to and is it neccissary to set base timing on LT1?
2) Is it possible to have the opti in 180 degrees out?
3)I am using an OBD2 opti but an OBD1 engine harness and ECU, I am told this should work, is this true?
Old Feb 27, 2006 | 10:48 PM
Firebat's Avatar
1) There is no base timing for an LT1
2) Not sure, but its possible to put an opti in wrong, especially a 92-94.
Check fuses, check wiring, exhaust leak, vacuum leaks. Get an automovtive stethoscope and listen to each injector. I know on mine with that tool i could hear each one ticking.
Do you have data logging software, aldl cable and computer to see what else is happening?
Old Feb 28, 2006 | 07:13 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Mine was doing this originally, and it turned out I only had one set of injector wires hooked up. 2&6 and 3&5 were firing only, after I fixed that, everything fired right up.
Nothing different on the OBDII opti from the '95 model.
As for getting it out, as long as you put the square notch on the pin, it's safe.
Old Feb 28, 2006 | 07:59 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
The late style opti can only go on one way. trying to put it in wrong will result in a broken opti, and you'll know it immediatly when you bolt it down.
Old Mar 1, 2006 | 10:27 PM
LT1powered89's Avatar
Car: 1989 Chevrolet Camaro
Axle/Gears: 2000 rear, 3.73, auburn locker
My car was doing something similar. I didn't have the O2 sensors hooked up because I didn't havea Y-pipe made yet so I thought it wouldn't matter. I found out the hard way and learned from my mistakes.
eightsixseven
Dec 16, 2024 01:50 PM
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
