LT1 fuel pressures?
Old Mar 10, 2006 | 08:00 PM
Firebat's Avatar
LT1 fuel pressures?
Just double-checking stuff. What fuel pressures should i be seeing with key on engine off, engine at idle, and then wot or simulated wot(vac line off of regulator)?
Old Mar 11, 2006 | 10:24 AM
TexasLT1's Avatar
Car: '92 RS
You should see 43.5 psi if you prime the system, should be around that at idle, not sure about WOT.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
