tacho question!
Old Mar 30, 2006 | 06:35 PM
xomega's Avatar
Car: 1990 chevy camaro rs
Engine: lt1
Transmission: 4l60e
Axle/Gears: 273:(
tacho question!
in this engine swap. lt1 in a 90 tbi camaro. i have wired everything up. i also have a aftermarket tacho.... when i started the car i reved it alittle. not to much. the aftermarket tach read 2,000 which is about right. but the factory just coasted up to about 5,000 or so and wheni let off the gas it drifts back down to 1500 again. is there a way to fix this?
Old Apr 2, 2006 | 11:32 PM
dbrunner2's Avatar
Car: '89 Camaro RS
Engine: 1994 F-car LT1
Transmission: T5 World Class
Axle/Gears: Jag XJ6 IRS, 3.42, Auburn Pro posi
All I can think of is to check your wiring for a bad connection to the factory tach, or bad ground to the factory dash, since either could allow the tach to pick up ignition noise. Seems odd for it to happen at high revs only though; does the factory tach read correctly at idle?
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
