Carb'd LS1 ....Any1 done it?
Old Jan 26, 2006 | 11:55 PM
carbed82_Z28's Avatar
Car: 82 Z28
Engine: She's motor-less!
Transmission: th-350
Alrighty, i posted this because i want to know if anyone has run this kit on their LS1 swap?
I am talking about the Edelebrock/MSD kit...
Does any one know anyone that knows anyone that has worked with this kit or can refer me anywhere that has some good info on it?
If so, it would be much appricated!
Old Jan 27, 2006 | 01:33 PM
ThirdGenLS1's Avatar
Car: 1991 Camaro
There's a guy named TJ over on LS1tech.com that has done it, dont know if he's ever posted over here, but heres a link for it over on LS1tech
http://www.ls1tech.com/forums/showthread.php?t=322905
Justin
Old Feb 18, 2006 | 07:00 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
oh man!
thats me!
i love the carbed setup. it was in my budget and already had the fuel system ready from my SBC.
i would recommend the MSD unit over the edelbrock. there are no adjustments to the edelbrock, not even a revlimiter.
i run the GM single plane intake, as i didnt feel the dual plane edelbrock would get the job done.
i gotta buddy that just the new victor jr kit, and it looks to be similar to the GM intake, but with a larger plenum.
ive since went a lil faster since the additon of headers and a lil carb tuning.
7.24 at 96.96mph cam only.
its fun, and a great swap. i can make changes all day long and not have to worrry about getting "retuned"
good luck!
Old Feb 20, 2006 | 01:47 AM
Car: 82 Z28
Hmm i thought the edlebrock and MSD kit were the same?... I thought they teamed up on this?...How much did the gmpp intake cost?....
Howd you go about your fuel system? ..
Can ya give me some general tips on your installation?
Anything helps!!
Old Feb 20, 2006 | 09:36 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
Anything helps!!
its made by SMD for edelbrock, MSD now has one under their own name that is tuned via PC.
the gm intake was right at 300 bucks, as is the new VICTOR JR.
i already had my fuel system.
-6 line, aeromotive rg, etc. any std carberated system in place will work, given it can support your HP level.
the only tip i can say on installation is watch what motor mounts you buy.
i bought a cheap kit off ebay and they are a lil off.ended up welding them to my stock SBC solid mount and trimmed them up and painted them.
the spohn mounts i think would be a nice choice.
i dont run a/c, but there are problems with the compressor and such.
either buy a bracket or get a tubular k member. id take the k member.
its pretty straitforward. no real issues.
Old Feb 21, 2006 | 01:02 AM
Car: 82 Z28
So your telling me i can buy the MSD kit seperate?...If so, can you dirrect me to the place i can find some, also for the gmpp intake....Where's a good place to find one?...
Also, i do not have the stock LQ4 brackets for alt, ps etc? do you know how i could get around using the stock brackets?
Also, got any pics?...I would like to see some pics!
Old Feb 21, 2006 | 08:46 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
for an adjustable system, the MSD box would be your choice.
start retard
timing controls
2 timing retards
rev limiter
and you can datalog with a laptop just like efi, just not as complex.
the edelbrock box you plug up and thats it.
the timiing pills included with the kit do nothing, IMO.
ive dynoed and ran at the track with them all. no difference.
scoggin dickey is the cheapest place for the GM intake, and jegs has the best deal on the edlebrock kit.
the msd part # for the box is #6010 if that helps.
Old Feb 21, 2006 | 09:00 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
there are several pics in the ls1tech link above of the car and motor.
Old Mar 11, 2006 | 12:39 PM
SnkSknrZ28's Avatar
Car: 1988 Camaro IROC-Z
do this instead
Old Mar 11, 2006 | 05:36 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
Originally posted by SnkSknrZ28
do this instead
ah looks nice, but all that weight gonna slow ya down.
that looks pimp!
Old Mar 21, 2006 | 12:34 AM
Car: 82 Z28
start retard
timing controls
2 timing retards
rev limiter
So tell me this, does this MSD box a straight plug n play?...Or is there wiring that needs to be done?
I think i am going to go the gmmp way, just in case down the road i can chance over to FI a bit cheaper!....
Old Mar 21, 2006 | 02:18 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
check into the victor jr. there is a version now machined for fuel rails and i think it even comes with them for 400 or so for everything.
just the intake is 289.
the MSD box comes with a harness, as far as i can tell. they also make an extension harness if you want to tuck it away somewhere.
i cant say for sure, i still run the edelbrock box.
ill switch one day, i like the extra features of the MSD.
good luck.
Old Mar 29, 2006 | 06:23 PM
BigMike92Z's Avatar
Car: 2006 Pontiac GTO
Transmission: rowing through 6 gears
Stage20, just wanted to send out a thanks. I've been looking at this swap for a while now. MOney situation didn't allow it before and now that I'm back into starting it all over again your information is still EXTREMELY helpful. Big thumbs up to ya...
Old Mar 30, 2006 | 12:32 AM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
Forgive my ignorance, but wouldn't running a carb on an LSx severly limit performance? Everything I've ever read says that the LSx intakes are designed rediculously well('specially the LS6 intake), and are almost impossible to beat performance wise. Not saying you shouldn't do it, just wondering how well it works compaired to the factory intake/EFI.
Old Mar 30, 2006 | 11:05 AM
Zarlor's Avatar
Carb'ed LS2 - Done
445 HP stock LS2 with GMPP intake, MSD spark control, and a 750 cfm carb. at the crank on the dyno. Currently installing a 505 HP LS2 (hot cam & CNC heads) into an '89 Camaro IROC.
Old Mar 30, 2006 | 12:54 PM
BigMike92Z's Avatar
Very nice Zarlor. Any major differences/hangups witht he LS2 install vs. LS1?
Old Apr 3, 2006 | 07:53 AM
Zarlor's Avatar
LS2 vs. LS1
No big changes between the engines. One will easily swap for the other. However the knock, crank, and cam sensors are in different positions. GEN III vs. GEN IV LSx engines. All else is interchangable.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
customblackbird
Oct 1, 2015 04:30 PM
dbrochard
Sep 19, 2015 08:13 PM
timonator
Sep 17, 2015 06:57 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
