how much did u pay
Old Apr 7, 2006 | 11:07 AM
nesqwick_05's Avatar
Car: 87 transam
how much did u pay
after u bought ur motor, transmission, wiring, what all did u pay and for what, with your LT1 swaps, im looking for an average amount i might spend after the motor transmission and wiring harness
Old Apr 7, 2006 | 11:16 AM
Leader_One's Avatar
Car: 1990 TA, 1995 Sierra 1500
Engine: 305tpi to LT1 mod, 305 TBI
Transmission: 4L60E with 3000 Stall, 5spd
just roughly estimating I think I am into my swap 2000 to 3000 dollars.
This includes
engine 800
rebuild 400 or 500
wiring harness done for me along with feul and PS line 375
tranny I traded my rebuilt 700r4 for a rebuilt 4l60e
hoses, battery, coil, blah blah blah 800 or so
Old Apr 7, 2006 | 11:31 AM
CamaroKid89RS's Avatar
Car: 89 Camaro RS/SS
Axle/Gears: 10 bolt with 3.42
I spent 2000 on engine and tranny, and expected about 1000 for parts required, random stuff, ect. 3000 total.
Old Apr 7, 2006 | 12:27 PM
Firebat's Avatar
95 LT1 Caprice PS lines from parts store(o'reileys) - $35
Fuel lines from Z 2 8 R I C E R - $125
Hooker Headers and Exhaust, and Magaflow Cat - about 700
TPI fuel lines and sender unit and TPI Walbro pump(to convert to FI) - $200
LT1 Vortec Elbow (cause the rubber ones are crap) and ebay LT1 CAI kit - $135
Programming - Madz28 email tune, ALDL Cable, Tunercat and Tunercat Def Files with free tunercat updates - $190
exhaust and headers were my biggest expense
Old Apr 8, 2006 | 08:19 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
$250 for the T56 crossmember
$20 for fuel lines
$35 for custom made PS lines
$150 for a new Walbro pump
$20 for motor mount clamshells
$150-200 various wire splicing items
$190 Hedman headers
$90 Hedman y-pipe
$120 custom 3" exhaust (no cat)
Oh yeah, $10 bucks to make my ALDL cable and $20 on the Tunercat def file
I didn't buy a custom wiring harness, there is no need......8-12 wires and you are set.
Old Apr 8, 2006 | 08:43 AM
Car: 87 transam
ic, how much is the VATS module?? and u need it dont u?? and how hard is it to "notch" the frame for AC??
Old Apr 8, 2006 | 11:06 AM
Firebat's Avatar
dont need a vats module. Could have it programmed out or use a resistor. If you remove smog/egr/air while doing the engine swap you'll have to have that programmed out too.
Notch out probably isn't the right term. Take a 20/24 oz hammer to the frame. Should be able to tell where once trying to get the engine in.
Old Apr 8, 2006 | 02:07 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
My VATS bypass module was only $30 from e-bay, and at the time, was an easier solution than the resistor. Only 3 wires to connect right at the PCM instead if chasing them through the dash.
To "notch" the frame for the A/C, all you really need to do is locate wher it needs work, and dent it in a bit with your BFH. You don't need to do any cutting or welding.
Old Apr 8, 2006 | 06:29 PM
Klortho's Avatar
Car: 1987 GTA
You don't really need a VATS module, if you know someone who can program it out of the PCM, that's the easiest way. Just like the other said, a BFH will do wonders on the crossmember.
ZEEYAA
Apr 16, 2023 08:29 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
ronscott80
Interior Parts Wanted
Oct 13, 2015 12:26 AM
Royal_Z
Sep 30, 2015 08:45 PM
