92 camaro lt1 swap with 92 corvette wiring help
Car: 92 Camaro RS 25th Anniv
Engine: 93 LT1 w/Vette Access
Axle/Gears: 97 T/A w/3.42 posi
I have searched the forums for any info on wiring a LT1 with corvette harness. No luck. The 92 vette has different pcm connectors, has anyone done the wiring with a 91-93 corvette harness? And where would be a good place to get the PCM programmed to eliminate egr, smog, and vats?
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
If you want just a basic tune on the car, or want something that can open the car up, I would recomment Bryan Herter at PCM4Less, he is what just about everyone in my area uses for LT1 tuning, however......the '92 PCM you have has a chip instead of being able to be flashed, so you will need to find someone who can do that, and I believe that Bryan can.
And that beast motor you have I believe is a one only year motor possibly '92-93 but if the PCM pinouts are different, it is very likely that it is a one only motor.
Engine: RamJet 350 running EZ-EFI 2.0
Transmission: Richmond 6-speed
Axle/Gears: 4.1
look about 2/3's down this page for pinouts...
Chevythunder
or here....
1992-93 LT1 schematic page 1
at the bottom of the second page the rest of the schematics are listed.
or here....
1992 Trans Am
Aug 8, 2015 08:16 PM
