LT1 Heads, GMPP Carb Intake on Gen 1 Block(?)
Car: 89 FireChicken
Engine: TBI
I've seen the write up about using LT1 heads and intake on a Gen1 block, but what about using the GMPP LT1 Carb Intake with them? Would I still have to block off those two (perhead) large water ports, or would a Gen 1 Gasket solve that problem?
Car: 89 FireChicken
Engine: TBI
Hey thanks.
Okay, so I'll still need to have the plugs done. Other than that, you think it would be worthwhile? So which head gasket do you recommend?
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Here's the thread on where a guy converted a set of LT1 heads to work on a Gen1 motor
https://www.thirdgen.org/techbb2/sho...ead+conversion
theshackle
Mar 5, 2017 06:37 PM
