Notched my crossmember today... Pics inside
Old Jun 8, 2006 | 07:29 PM
Nick89TA's Avatar
I just pulled out my engine crossmember and took the 'ol cut-off wheel to it. I am going to hava a professional welder friend of mine fill it with some plate steel. GTA91, i used your pics as a rough guide, hehe. Does this look like a big enough notch or does it need to go further back towards the mount? Pics below
Old Jun 8, 2006 | 11:16 PM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
Axle/Gears: soon to be 3.73's
just glue some cardboard in there and you're golden. lol
Old Jun 11, 2006 | 12:16 PM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
Well, if your engine is out, bolt the k-member up to it and see if the A/C fits. That's what I did.
Old Jun 11, 2006 | 03:25 PM
beedo's Avatar
Car: 1986 IROC CAMARO
Axle/Gears: 3.73 posi
Be sure you took out plenty of material cause I didnt and have a nasty grinding noise. Check it a few times.
Old Jun 12, 2006 | 05:16 AM
TexasLT1's Avatar
Car: '92 RS
looks like it needs to go back a little further. I think mine goes almost all the way back to the edge of the engine mount.
Old Jun 13, 2006 | 03:04 PM
tuske427's Avatar
Car: 1984 Trans Am
Engine: 2002 LS1
Transmission: 6 speed
Axle/Gears: 3:73
they have pics of this notching onthe fbodymotorsports website. you could compare it to those pics...
Old Jun 16, 2006 | 06:21 PM
Nick89TA's Avatar
My buddy tried the cardboard, damn welder kept burning through it
Super_kev, I agree, take a look below
Here is what the k-member looked like after welding
This is the clearance from the front of the engine, i hope when the engine weight is actually loading the mounts my clearances don't change too much.
This is a view from the top, with the ACSource.com hoseblock mounted. The socket head cap screw was thrown id there just for mockup, but i still don't think a hose nut will clear with the OEM hex head either. That block doesn't seem to seal well either, hmmm.
This is what i got so far, with the hawks headers bolted on one side to show clearances
That's all i can handle for now, it's like 95 in my garage and humid. Friggin Chicago weather
Hotrodboba400
Dec 10, 2019 07:07 PM
Lanz06
Mar 13, 2019 06:07 PM
Fronzizzle
Sep 8, 2015 12:10 PM
lakeffect2
Sep 7, 2015 03:52 PM
Ian Irvine
Sep 4, 2015 08:08 AM
