Pre Ignitioning
Old Jun 22, 2006 | 08:35 PM
red_82_z28's Avatar
Car: 1982 Z28
Transmission: 5-speed
Pre Ignitioning
Ok, Put the Lt1 in Hot can kit etc. etc well it Idle with the Maf off checked and found I didn't plug the vac. port under the throttle body so i pluged it. before I was noticing a pre ignition noise when I wen't to rev it up a little.. Its doing the same thing. but now when i have the Maf hooked up it still does it and will die after a few seconds if you arn't holding the throttle and it gets louder. Please help I can also tightened up the rockers a little, so there not as loud. well there's my problem. but i look on the bright side at least it runs .
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
94ElBanditoDeCa
Aftermarket Product Review
Sep 23, 2015 09:05 PM
RedLeader289
Sep 23, 2015 06:50 AM
