4th gen tank wiring
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
4th gen tank wiring
ok so there is a product out there called a fuel pump hot wire kit. you can either buy it with a 255lph pump or just the wires. form like thunderracing or ebay for like 66 bucks. anyways it runs the fuel pump off the altenator. 12 gauge wire to the back so no voltage drop at higher rpm. its a pretty slick kit. so yeah. check it out.
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Mine is run off of the battery, so I don't get a voltage drop at high RPM either since the wire coming off of the alternator goes directly to the battery and that goes into my junction box, and I saved 66 bucks.
Car: 1984 Camaro Z28
Engine: 2000 LS1
Axle/Gears: Moser 12 bolt w/4.11's
Originally Posted by 92camarors5spd
thats what i called it. fuel pump hotwire kit.
AkDrifted
Aug 17, 2015 07:45 PM
