lt1 runs on 4 cylinders
Old Jul 28, 2006 | 10:45 AM
rokn91rs's Avatar
i put a 93 lt1 in my car. once i got it running i realized it was only firing the passenger side injectors. i hooked both of the injector wires from the c100 plug up to 12 volt switched wires. only one of them works and the other does nothing. i was thinking maybe it was in limp mode is this possible? any ideas would be helpful.
brian
Old Jul 28, 2006 | 10:57 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I had the same problem when I went from TBI to TPI. It ended up being the plug under the dash that went to the ECM. I didnt get it snapped together all the way and only one side fired.
Dont know that this will help with the LT1. Just thought I would throw that info out there.
Old Jul 28, 2006 | 12:05 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
What year motor and harness? I had the same thing, the '95+ harness have the injector wires in two different plugs. The C100 and the smaller plug that is with it.
Old Jul 28, 2006 | 01:31 PM
rokn91rs's Avatar
as it says above 93 engine, harness, and computer. i don't have the knock sensor hooked up or an oil pressure switch. could that cause this?
Old Jul 28, 2006 | 01:42 PM
Klortho's Avatar
Car: 1987 GTA
Ok, didn't see the '93. Those are a beast of their own since they are batch fire injectors. You may want to look at hooking them up to two different fuses, and make sure that the wires are not damaged between the ECM and the injectors on that side.
Not having the knock sensor or oil switch hooked up won't cause this.
Old Jul 28, 2006 | 05:12 PM
rokn91rs's Avatar
well i started moving wires around and i guess some wire wasn't getting enough voltage. it runs on all 8 now but has a bad miss i am guessing is ignition related.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
db057
Aug 22, 2015 08:17 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
