97 LT1 to 700r4
Old Sep 8, 2006 | 06:49 PM
jjohnston's Avatar
Car: 91 Camaro RS
97 LT1 to 700r4
I found that part of the wiring harness is supposed to plug into the top of the transmission. However the transmission doesn't have a place to plug it in. because the 97 block used the 4l60e trans, and I have the 700r4. what needs to be done?
Old Sep 8, 2006 | 09:08 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
The 4l60e tranny
Old Sep 8, 2006 | 09:13 PM
jjohnston's Avatar
Car: 91 Camaro RS
No, its possible without. I swear ive heard that... I just don't have $2,000 for a trans now.
Old Sep 8, 2006 | 09:27 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
been covered many many times, a search will turn up tons or info. Basically, you need a '93 TB or adapt your linkage for the TV cable on teh 700R-4 and tune the computer to ignore the trans.
Old Sep 8, 2006 | 09:30 PM
jjohnston's Avatar
Car: 91 Camaro RS
OK, I did get all those parts. I was just confused on hooking the computer to the trans. so I just need to ignore that, then reporgram the computer to ignore it too. Thats what I needed. Thanks!
Old Sep 9, 2006 | 03:15 PM
Firebat's Avatar
You don't even have to reprogram the computer to make it functional but I think you might throw a code for tcc. I assume you are using a 4l60e VSS and 4l60e reluctor, TCI lockup kit. You just need to connect the VSS pigtail connector to the VSS and wire/install the lockup kit.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
