Progress on FM LS1 Turbo
Old Jan 3, 2007 | 06:41 PM
25thRedRS's Avatar
Car: 1992 Camaro RS
Transmission: T56/B&M/Ls7
I am currently building a homemade Front Mount LS1 Turbo project....I am using exhaust manifolds from a 98 Camaro and turning them forward.
Other parts:
Turbonetics T-76
Turbonetics Racegate Wastegate
Turbonetics Godzilla BOV
Large FM intercooler.
60 lb injectors
Walbro 355 Fuel Pump
and many more
here are some progress pics...Still a lot of work to do.
[IMG][/IMG]
Old Jan 3, 2007 | 06:49 PM
25thRedRS's Avatar
Car: 1992 Camaro RS
[IMG][/IMG]
Old Jan 3, 2007 | 07:22 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
WOW!!! looks like its going to be alot of work! Cant wait to see this when its all done. Good luck
Old Jan 28, 2007 | 09:09 PM
25thRedRS's Avatar
Car: 1992 Camaro RS
Old Feb 7, 2007 | 06:01 PM
25thRedRS's Avatar
Car: 1992 Camaro RS
Old Feb 7, 2007 | 06:09 PM
25thRedRS's Avatar
Car: 1992 Camaro RS
Old Feb 8, 2007 | 10:08 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
wow nice project you got there. Im interested in seeing the finished product. Im doing something similar
Old Feb 9, 2007 | 02:41 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
How much boost you think that hi comp ls-1 will handle ? Nice project! cant wait for updates.
Old Feb 20, 2007 | 10:27 PM
25thRedRS's Avatar
Car: 1992 Camaro RS
Heres the latest update...All pipes are done and getting heat wrapped at this time. Then it's time to put everything back in, finish up the fuel system, and get this thing tuned....I'm only planning on running about 8 lbs. of boost seeing that the stock LS1's dont like more than 600 HP. I'm hoping to make somewhere right above 500 rwhp.
Old Nov 4, 2007 | 12:16 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
Re: Progress on FM LS1 Turbo
Holy old post Batman...I want more pics and info!
Old Oct 19, 2008 | 01:10 PM
82z28man's Avatar
Car: 91 Z28
Engine: 6.0 LSX Single turbo
Transmission: 4l80E
Axle/Gears: Moser 9" 3.55
I know that this thread is ancient but i also want to do a fm turbo when i swap in my 6.0, and i wanted to see how you liked your setup. Could you have fit the turbo between the engine and radiator if the fans werent in the way? And can the passenger side manifold be flipped without being modified like you did? thanks for any help
Old Oct 20, 2008 | 08:06 AM
25thRedRS's Avatar
Car: 1992 Camaro RS
Yes I loved my setup....but I'm currently in the process of changing it...I could not fit it between the radiator and the motor ....I never tried it without the fans in but it might have possibly fit. I don't recall about the manifolds sorry..
I'm currently in the process of changing my whole setup with a custom core support so it's going in between the motor and radiator this time...
Old Oct 20, 2008 | 05:03 PM
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
I was also planning to use the t76 with my setup at about 10 lbs. How much rwhp are you making with yours up to 10 lbs now? Much lag? Thanks for your time.
Old Oct 21, 2008 | 09:09 AM
25thRedRS's Avatar
Car: 1992 Camaro RS
I was making 538 rwhp on 10lbs but that was only at 4800 RPMS because my fuel pump couldn't keep up. Not much turbo lag since I chose to go with a smaller exhaust housing ( a .81 a/r)...Any other questions let me know
Old Nov 23, 2008 | 01:19 PM
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
Do you recall what the dimensions were on the intercooler? thanks
Old Nov 23, 2008 | 07:08 PM
25thRedRS's Avatar
Car: 1992 Camaro RS
I believe it was 18x30x3.
Old Nov 30, 2008 | 12:32 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Have any updates on your new setup? I see a turbo in my future! Any pointers?? What kinda pump are you running (fuel). Thanks!!
Old Dec 3, 2008 | 09:27 AM
25thRedRS's Avatar
Car: 1992 Camaro RS
Yes their are updates..I just forgot to post lol....The car is coming together, I will post pictures soon...I changed my fuel system to a sumped system and am running a Magnafuel 4301 pump.
Old Dec 3, 2008 | 11:55 AM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Good looking set up, were you able to sneak in any track passes before the cold weather?
Old Apr 11, 2009 | 12:21 AM
T TA 355's Avatar
Any more pics of the dp?
bjpotter
Oct 4, 2015 07:48 PM
dusterbd
Sep 29, 2015 08:40 AM
