Cheap 96 LT1 timing set
Old Mar 18, 2007 | 06:46 PM
92lt1bird's Avatar
Is there one for under $100...
Old Mar 19, 2007 | 07:42 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
No, main reason is the cost of the cam gear.
Old Mar 19, 2007 | 06:50 PM
92lt1bird's Avatar
Whats the cheapest!
Old Mar 19, 2007 | 08:19 PM
Klortho's Avatar
Car: 1987 GTA
Cheapest I found one was around $180 or so which was a Cloyes from AutoZone. The GM LT4 Heavy Duty set is around $240 or so last time I checked.
Old Mar 21, 2007 | 03:40 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
Re: Cheap 96 LT1 timing set
You can get GM set, here are the part numbers,
10206039 Cam sprocket around 32.00
10128346 Crank sprocket around 25.00
10128485 Chain itself around 28.00
around 85 bucks plus shipping, this was priced from gmpartsdirect.com
May want to double check the partnumbers tho on shbox.com he has complete part number breakdown.
Kevin
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
midge54
Jan 29, 2017 07:00 PM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
Thirim
Aug 9, 2015 06:19 PM
