lt1 swap
Old Mar 29, 2007 | 09:16 PM
3rdgen92maro's Avatar
Car: 1995 Firebird Formula
Transmission: Th350/4k stall
Axle/Gears: 10 bolt with 3.42s
lt1 swap
im gettin ready to swap a 94 lt1 into my 91 z28 camaro. i was woundering how long this will take. i have the whole harness, ecm and fuse block.
Old Mar 30, 2007 | 03:47 PM
jagevileye21's Avatar
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Axle/Gears: 3.42 LSD
Re: lt1 swap
I had the TPI out and LT1 in about a 1-1/2 days mainly because it my motor mount was backwards and I couldn't get it to sit properly. I probably took another 3 days on the wiring just to be sure I had it right. Its not a long process as long as you have everything you need at hand before you do the swap. This was my first time doing an engine swap, period. However, working out the kinks seems like its taking forever.
Good luck,
Jay
Old Mar 30, 2007 | 09:48 PM
Re: lt1 swap
how many connections are there to be made?
Old Mar 31, 2007 | 01:24 AM
Car: 1991 Z28 Vert
Engine: LT1 350
Re: lt1 swap
I can't remember exactly but I had think it was about 12 or so. I had my harness modified by Dana @ LT1350.com so it made it a little easier because everything was labeled.
Jay
Old Mar 31, 2007 | 08:01 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: lt1 swap
Well, let's see.....injector power (switched), ignition power (switched), PCM power (switched), PCM power (constant hot), oil pressure, temp, battery, purple ignition wire, fans, check engine, serial data (for the ALDL), speedo, tach....
that should just about cover it.
Old Mar 31, 2007 | 01:44 PM
Re: lt1 swap
it doesnt sound to hard at all it thats the only connections that have to be made. im pretty experinced with wiring and stuff. im gonna have like 10 days to do it do yall think it could be done in that amount of time
Old Mar 31, 2007 | 11:18 PM
TexasLT1's Avatar
Car: '92 RS
Re: lt1 swap
10 days shouldn't be a problem. I would try to have fuel and powersteering lines handy and ready to go though so you don't have to spend a lot of time futzing with them.
Old Apr 1, 2007 | 12:59 AM
Re: lt1 swap
yeah i hope it only takes a few days, cause im home on leave for 12days in apr and was hopin to have it done with in that time frame
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
