A couple of wiring questions.
Old May 10, 2007 | 11:44 AM
jagevileye21's Avatar
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Axle/Gears: 3.42 LSD
Where did you guys wire your TCC power?
-Dana @ LT1350.com said this wire should receive ground in park or neutral.
Where is the best place for this wire?
Where did you guys wire you Power neutral feed wire?
-Dana @ LT1350.com said this wire should receive 12volts when the brake pedal is not depressed.
Any help would be greatly appreciated.
Thanks,
Jay
Old May 11, 2007 | 06:19 AM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Re: A couple of wiring questions.
Hmmm Im not familiar with LT1 wiring, but isnt it the ECM dealing with the ground/power to the TCC? I mean, with the inputs of other sensors (VSS, TPS, ...) it turns on or off the TCC? I beleive its wired that way on LSX's
Old May 11, 2007 | 10:18 PM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
I'm in the same exact situation. I can tap into the wires, but they're are in the interior. When I first got the harness, Dana said that I could get everything I need from the harness under the hood. So, If anyone knows, I'd like to hear the answer too!
Old May 12, 2007 | 01:08 AM
Car: 1991 Z28 Vert
Engine: LT1 350
Whiteblaze,
On 89-91 Camaros you can wire the TCC up at the bulkhead(C100) purple wire pin E7.
For the PNP Signal I wired it up at the 15 way I/P connector(C207) to the black and orange wire. I can't recall which pin right now though. Or you can just wire it right up to the neutral saftey switch on the shifter.
Jay
specialized
Jun 18, 2022 09:26 AM
Cleotiz
Jan 6, 2018 08:56 PM
69 Six Pack
Oct 5, 2015 07:51 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
