More lt1 wiring questions...
Old Jun 3, 2007 | 10:54 PM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
Transmission: Tremec 3550
I must be a real dummy cause the wiring for dummies article only help a little.
The info I have locate on the matter says almost all of the connections will be at the c100 on my 3rd gen. So I think I can follow this diagram I have and work this out. But what is connected at the c207?(bulkhead under passenger kick right?) Do I just remove most of this? Trace down what was connected to the ECM and cut it off?
Also what about VATS? I still have it, although bypassed with a resistor. How do I hook this up or do I have to delete it from the PCM? (I know it is easier without it I just don't have the cash for tunercat right now)
Old Jun 4, 2007 | 03:43 AM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
Re: More lt1 wiring questions...
for me, the c207 is where i connected the following:
torque convertor clutch control
park/neutral feed
diagnostic request
SES
serial data
power feed for both injector (2 wires twisted with a blue and a green i think)
power feed for ignition
i think that's it. maybe a ground too, not sure.
don't know about VATS though...don't have it.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
midge54
Sep 2, 2015 06:27 PM
midge54
Aug 29, 2015 09:51 PM
