High Idle...LT1
Old Jun 12, 2007 | 07:56 PM
jagevileye21's Avatar
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Axle/Gears: 3.42 LSD
High Idle...LT1
I have a 91' Z28 with a 95' LT1 & 4L60E in it. I been reading about setting the throttle to the minimum air position. Before I do anything though I wanted to make sure I could do this with an LT1?
Okay on to my problem.
When first start the car the idle is very high then after it warms up it will drop down to around 1500RPM. When I put the car in drive it either stays around 1500RPM or it might go up to 2000RPM. Sometimes even surging up and down. My initial thought was maybe a vacuum leak, but after testing it yesterday the vacuum tester showed a steady pressure between 20 & 22Hg. (17-22Hg is normal operating condition for an LT1).
In addition the the high idle in park and in drive the SES light is now coming on. Should I be able to read codes with a paper clip like regular thirdgens? If so how should I go about doing this?
Last Question:
Do you think these problems would keep my car from performing right at highway speeds?
Any help you can offer would be great.
Thanks in Advance,
Jay
Old Jun 13, 2007 | 09:04 AM
Firebat's Avatar
Re: High Idle...LT1
There is a throttle stop screw on the throttle body. The IAC might also be dirty.
I don't know anything about using a vacuum tester so I don't know if you still have a vacuum leak. A couple other ways to test is to spray small amounts carb cleaner around the edges of the intake manifold(be very careful) and if there is a leak the engine will react to the carb cleaner. Also, sealing the intake off(while having the engine shutoff) then use a vacuum pump and see if it holds the air in.
You read codes by using an aldl cable and software from a computer/laptop.
Old Jun 18, 2007 | 01:01 AM
Car: 1991 Z28 Vert
Engine: LT1 350
Re: High Idle...LT1
I tried to spray alittle carb cleaner around the intake but the idle did not change. My only guess now is that one of the sensor is bad because the SES light comes on as soon as I start the engine, which in return makes the fan come.
Thanks,
Jay
Old Jul 19, 2007 | 10:22 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: High Idle...LT1
Thanks,
Jay
Take the IAC off the engine, spray it CLEAN with throttle body cleaner, and then spray the IAC air passage and the throttle bores/blades as well. Do it untill its all clean - may take more than one can of cleaner to do this.
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Zell1luk
Sep 29, 2015 10:36 AM
