700r4 vs. 4l60e
Old Jun 20, 2007 | 10:53 PM
wiseman9986's Avatar
Car: 82 z28
Transmission: TH350
Axle/Gears: 10 bolt 3.73
700r4 vs. 4l60e
i changed my track of mind and i am now doing a ls1 with a 4l60e swap but i already have a brand new spohn torque arm acnd crossmember for a 700r4 swap spohn said they would sell me just the crossmember since thats all thats different but i thought the 700 and 4l60e were phsically the same what will i have to do to make this work?
Old Jun 21, 2007 | 08:31 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Re: 700r4 vs. 4l60e
The case is different in the 4L60E. Its the internals that are the same minus the electronic controls in the 700 of course. I though the mount was in the same location though so???
Old Jun 21, 2007 | 10:55 PM
Car: 82 z28
Transmission: TH350
Re: 700r4 vs. 4l60e
well what kind of modification do you have to make to a stock 700 crossmember?
Old Jun 25, 2007 | 12:42 PM
SweetRide45's Avatar
Re: 700r4 vs. 4l60e
4l60e uses the stock 700r4 mount and crossmember
Old Jul 2, 2007 | 01:25 AM
1991 RS/SS's Avatar
Car: 1991 Camaro RS
Engine: 383 LT1
Axle/Gears: 4.10
Re: 700r4 vs. 4l60e
This is true. 4L60e will bolt directly in place of the 700r4.
Old Aug 19, 2007 | 08:37 PM
scarfache's Avatar
Car: 1982 Firebird SE
Engine: LS
Axle/Gears: Unknown
Re: 700r4 vs. 4l60e
can you use a 700r4 with an LSx engine or do you have to use a 4l60/80 trans?
Old Aug 19, 2007 | 11:43 PM
socal's Avatar
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
Re: 700r4 vs. 4l60e
The mounts are the same but the lsx crossmenber is differant. I just got my sphon touq-arm as well and they said the same, but for now i got the stock cross member till i do the swap then i have to get the lsx crossmember. Follow the link and look at the dementions
http://www.tciauto.com/Products/GM/g...asp#dimensions
Old Aug 21, 2016 | 06:55 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: 700r4 vs. 4l60e
Super old post, but did you keep your 700R or did you upgrade? I'd like to keep my 700R but can't find any good info on what cross member works.
Old Aug 23, 2016 | 05:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The transmission mount location is different on the LS type 4L60E vs. the LT type 4L60E & TH700. So, if you use the transmission to locate the engine, you can use a 3rd gen TH700 crossmember.
Old Aug 24, 2016 | 10:40 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Re: 700r4 vs. 4l60e
Ok....so being a total n00b here and not finding anything when searching. Maybe my keywords are off
I picked up the Spohn 4L60E cross member, but this will not mount to the 700 because of the difference in cases. So I'll be sending that back. They do not make one that mounts to the 700R.
So that leaves me with eitehr swapping to a 4L60E or finding the correct cross member/adapter if the factory cross member won't work,
Can I use my factory cross member where the 700R is currently bolted when doing an LS swap? If not, that's cool, I just need to know what direction to look to make it work.
Old Aug 24, 2016 | 01:18 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Re: 700r4 vs. 4l60e
Just spoke to BMR, the Transmission Cross member with Torque Arm Relocation bracket, TCC-017, will work with a 700R4 and LS1 Swap.
Old Aug 24, 2016 | 04:54 PM
five7kid's Avatar
Looks like it will.
Old Aug 24, 2016 | 07:12 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Re: 700r4 vs. 4l60e
Looks like it will.
Yes, now to figure how to route exhaust !
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
