bouncing off the rev limiter at 5000rpm????
Old Jul 8, 2007 | 09:02 PM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
Ok I put a 95 lt1 in a 87 firebird and last year the car ran great. Since then i rebuilt the tranny and strocked the lt1 to a 383 with a direct port nitrous. So I go to the track this weekend to run the car and dial in the nitrous when on my first pass I notice that I bounce off the rev limiter at 5000 rpm.
I scanned the car and the only code that I came up with was code 97 (4K pulses per mile fault) which I had before I went racing. Eairlier in the week I replaced the vss try to get rid of the code but it was still their.
I also do not have the speedo hooked up to see if that is working properly. I bought the cable x to convert the 4l60e electronic signal to a mechanical one, its just not hooked up yet. S that does not help.
I reciently had the computer redone to set it up for the added cubic inch and nitrous, could the problem be in the computer and tied to code 97? Could the problem be that the injectors are to small? Could it be the tranny?
Thanks for you help
Old Jul 8, 2007 | 09:44 PM
xomega's Avatar
Car: 1990 chevy camaro rs
Engine: lt1
Transmission: 4l60e
Axle/Gears: 273:(
Re: bouncing off the rev limiter at 5000rpm????
had a similar problem to yours with a 95 lt1. i took it for a testdrive and romped on it hard it spun and kept spinning and hitting rev limiter, come to find out the computer was accidently programed for a m6 instead of a a4. naturally how you would tell is to see if itll shift out of first.
Old Jul 8, 2007 | 10:19 PM
Car: 1987 firebird
Transmission: 4l60e
I am thinking that the problem is in the computer and it is the reason I am getting code 97. It is shifting fine when driven normally, but when at wide open it bounces off the rev limiter?
Could it be in limp mode, with a lower red line?
Old Jul 9, 2007 | 12:05 PM
Firebat's Avatar
Firebirds from 1986-92 should have electrical speedos and you won't need a cable-x converter. Just hook up the output to the 3rd gen speedo wire. If you hook up the speedometer wire, it would probably get rid of code 97.
I'm not sure whats causing the rev limiter problem. To get my old thirdgen tach to work right, I had to get the tach signal directly off of the coil, not the tach signal that comes from the pcm.
Old Jul 9, 2007 | 02:13 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Do you happen to remember which wire you hooked it up to? Mine works, but drops out after a certain RPM with it hooked up to the signal wire from the PCM.
Old Jul 9, 2007 | 02:38 PM
Firebat's Avatar
In my notes I wrote: White/black wire, ICM connector pin B. The ICM connector is the one with 4 prongs on it. It says ABCD on the connector. I just looked at it now and it looks more like a yellow with a black stripe but maybe its dirty.
Old Jul 9, 2007 | 06:54 PM
Car: 1987 firebird
Transmission: 4l60e
Its an 87 firebird and it has a mechanical speedo. last year the car ran without the speedo with no problems or codes?
My gut is teling me that the computer was messed up but I am unsure.
I have accsess to a scanner can I scan the tranny to see what the vss is doing? What should I look for.
Is it possable that my injectors are too small and starving the engine at 5000rpm?
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
racereese
Oct 3, 2015 03:46 PM
drumstixer
Sep 29, 2015 03:02 PM
