throttle cable?
Old Jul 17, 2007 | 01:07 PM
1987earthquake's Avatar
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
throttle cable?
What throttle cable to use with 5.3L truck intake?
Thanks,
Eric
Old Jul 17, 2007 | 01:30 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: throttle cable?
I used a Lokar TC1000LSI on my 350 Ramjet. I know it isn't an LS motor, the cable is 36" braided, looks and works very good, that cable is supposed to work with LSX motors. might want to ask though and make sure.
Old Jul 17, 2007 | 01:42 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: throttle cable?
you can use the NON TCS fbody cable.
it fits in the stock 3rdgen firewall hole, but is a bit loose. you can snug it up with some padding and have it look OEM.. or weld the hole smaller. or just leave it.. it wont effect performance, just wiggle a bit.
you will have to put a spacer on the cable where it connects to the pedal.. i used a zip tie.
OR
you can jsut bend the pedal bracket.
either method works.
Old Jul 17, 2007 | 01:46 PM
Engine: 5.3L
Axle/Gears: 3.42LSD
Re: throttle cable?
how do I know which has tcs
Old Jul 17, 2007 | 02:12 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Re: throttle cable?
TCS fbodies have a cable going from the pedal to a bellcrank mounted on an actuator... then a second cable from the actuator bellcrank to the throttle.
non traction control fbodies have a cable that goes from the pedal, to the throttle.. thats the one you want.
Old Jul 17, 2007 | 02:48 PM
Engine: 5.3L
Axle/Gears: 3.42LSD
Re: throttle cable?
Thanks MrDude
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
L0tuS
Oct 4, 2015 08:07 AM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
