throttle cable
Old Aug 13, 2007 | 08:48 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
throttle cable
going to install my ls1 in the iroc in the next week. what are you guys doing for throttle cables, or is it as simple as just getting one from a 4th gen and snapping it into place?
Old Aug 13, 2007 | 06:44 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Re: throttle cable
Use the 4th gen cable....the hole in the firewall is a bit large though. You will have to get creative with a large thin flat washer and perhaps a ziptie wrapped up under the ears that snap it into place.
Old Aug 13, 2007 | 09:21 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Re: throttle cable
I snaked mine around under the fuel rail no ties nec. Washer through firewall with two small pop rivets like 406tpi says
Old Aug 13, 2007 | 11:50 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
Re: throttle cable
got any pics? and do they make a swap cable to buy?
Old Aug 14, 2007 | 07:22 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Re: throttle cable
Use a stock 99 throttle cable for a Non traction control car. The cable is different for traction control set ups. I highlighted the cable in pink and although you cant really see too well where it goes through the firewall i put two small dots to show where the rivets went through the washer into the firewall. Its the stock third gen hole its just too big for the clips on the LS1 cable to hold itself in there. I found a large plated washer that had a small hole so I file fit the shape out to retain the clips but as 406tpi said a zip tie would prolly do the trick just fine too.
Ignore the arrows all over this pic I already modified the file for another post and lost the original image
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
L0tuS
Oct 4, 2015 08:07 AM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
