Speedo problem
Old Sep 9, 2007 | 08:51 AM
kubus_stroinski's Avatar
Car: 1991 Camaro RS
Axle/Gears: Tru-Track posi/Moser axles/4.10
Speedo problem
Hey
I have one last issue to iron out with my LS1/T56 swap into my 1991 RS that has a 3.1L 700R4 before.
Anyways, when I turn the car on and Im in neutral my speedo reads 80 km/h. Also when I come to a complete stop it does this. When I rev in neutral the speedo will go up to 160 km/h. This is annoying because my odometer keeps going up when Im sitting still.
When I start driving, the speedo begins to work normally but its reading a bit low (ie it reads 45km/h and Im really going 50). I have the Dakota Digital box and I think its wired in properly. How did you guys set your dip switches? What else could be wrong here? Thanks!
Kubus
Old Sep 9, 2007 | 09:28 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: Speedo problem
You didn't need the dakota digital box for the speedo since yours is a '91 model with an electric speedometer. You could hook the speedo output wire from the PCM directly to the 4000ppm input wire where the VSS box is at and it will work just fine.
Old Sep 9, 2007 | 05:05 PM
Car: 1991 Camaro RS
Re: Speedo problem
are you 100 percent sure? why did everyone say i neeed one before?
Old Sep 9, 2007 | 05:18 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: Speedo problem
it's not needed but you would need to change the calibration in the pcm for it to read correct with your gear ratio and tire size.
if you do a search alot of the t56 swaps req. this when only using the trans from a lt1 car. since you don't have the lt1/ls1 pcm to change it.
often times if you use your stock speedo wires to the trans it will act like you are describing since they run near several things that creat interferance. alot of people end up running new wires.
Old Sep 9, 2007 | 05:36 PM
Klortho's Avatar
Car: 1987 GTA
Re: Speedo problem
The LS1/LT1 PCM has an output for Speedometer that outputs a 4000ppm signal. The 3rd gens with electric speedo's have a VSS buffer box that takes the signal from the tranny, and converts it to the 4000ppm signal. Since the LS1/LT1 PCM has this output already, all you need to do is hook that wire up to the green or tan wire where the VSS box is and it will work. Now like 350TPI stated, you will need to have it tuned to change the gear/tire size for the speedo to be accurate, or buy like a Hypertech programmer which will do it as well.
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
