A/C, coolant, and vacum help
Old Sep 18, 2007 | 09:46 PM
inuyasha_lost's Avatar
Car: 92 Camaro RS 25th Anniv
Engine: 93 LT1 w/Vette Access
Axle/Gears: 97 T/A w/3.42 posi
Ok I am reaching the end of my LT1 build and ran into problems. First I have the vette setup on mine. I was trying to make the P/S line from a caprice (need help here any suggestions) when I noticed that the A/C compressor didn't line up with the rest of the drive accessories. I am thinking it's the wrong one, but has anyone ran into this?
Second: How do I run the heater and radiator lines? The lower hose won't fit on the radiator.
Third: Help with vacum lines. Sizes, routing, and what should be bypassed?
Old Sep 19, 2007 | 12:58 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Re: A/C, coolant, and vacum help
The Caprice P/S line is way too long with the vette brackets. I ended up making one. Can we get some more details? Which radiator and water pump are you running? This will determine which hoses you run. If you are running the third gen radiator, you can use a lower hose for a 92 vette. If it is a fourth gen radiator, you can use a 93-97 Camaro hose. Do you have any pics of the A/C compressor problem? There are pics on my cardomain page that might help you.
Old Sep 19, 2007 | 08:05 PM
im using the standard LT1 pump with my 92 radiator. from what i can tell from your pics mine is the wrong A/C compressor. yours is much bigger than mine. yeah i was afraid of having to make my own p/s line. thanks for your info. your pictures are good, but i still cant get all the info from them for the heater lines.
Old Sep 19, 2007 | 08:15 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
My heater hoses are simple straight heater hose. 5/8 and 3/4 hose and clamps. I plugged the extra ports on the water pump with pipe plugs. The only port on the water pump I am using is the one on the top of the passenger side. It is 5/8. I ran a 3/4 hose from the steel pipe that runs along the frame on the passenger side to the return port on the radiator. The second pic shows my power steering line. These pics might help.
Attached Thumbnails A/C, coolant, and vacum help-picture-005.jpg   A/C, coolant, and vacum help-picture-006.jpg   A/C, coolant, and vacum help-picture-007.jpg
sheachopper
Jul 31, 2019 11:27 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
