MSD opti LT1 Timing check
Old Sep 21, 2007 | 07:29 PM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
I have reciently installed a MSD optispark on my 383 LT1 and want to double check my timing at the balancer since the MSD unit can be adjusted +/-7 degrees. Since I have a keyed ATI balancer with timing marks on it, when I installed my MSD opti I fabricated uo a timing pointer using a piston stop. Now when I check the timing at the crank I read about 27 degrees, about the same timing reading I see on the scanner.
Do I want to make the two timing readings match eachother? Or do I want to set the balancer timing to as close to zero as possable with the MSD opti? Is not the scanner reading ignition timing and I get cam timing on the balancer? I am thinking way to far into this and making my self confussed and need a second oppinion.
I just want to verify that the MSD unit is properly adjusted.
specialized
Jun 18, 2022 09:26 AM
midge54
Dec 27, 2019 04:14 PM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
Thirim
Aug 9, 2015 06:19 PM
