keep or kick the EVAP on a returless fuel system
Old Nov 2, 2007 | 08:36 AM
GM-LSX's Avatar
Car: Pontiac Firebird T-Top
Engine: V6 3.1 170HP and LSX swap in mind
Transmission: TH700-stock
Axle/Gears: 3.23 -stock
Hey Folks
I'm preparing to sell the the old engine and all the stuff I'll have no further use after the Swap. (i have no room)
Victim is a F-Body 1991 Firebird 3.1L V6 (LH0)
The new engine (that's at least the paln) will be an 5.3L GEN IV AFM Flex Fuel all aluminum (LC9) with a returnless fuel system. I'll use an 1998+ Corvette Regulator/Filter installed under the left hand back seat (in place of the old filter).
Do i still need the Vapor Canister on a GEN IV SBC ?
Old Nov 2, 2007 | 09:13 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The vapor canister vents the tank as the fuel level drops, and lets the tank breathe with temperature changes. It doesn't have anything to do with fuel return. So, yes, keep it.
Old Nov 2, 2007 | 09:41 AM
GM-LSX's Avatar
Re: keep or kick the EVAP on a returless fuel system
Now i got. Vacum is (also?) vented, not (just?) heated Air/Fuel.
Old Nov 2, 2007 | 07:50 PM
five7kid's Avatar
Right. The air coming out of the tank from heat expansion has to go through a charcoal bed to absorb the fuel vapors. The bed is "purged" by pulling air through the bed from the outside into the engine.
Similarly, when fuel level goes down and the tank needs air to replace it, it comes through the charcoal bed.
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
mustangman65_79
Apr 14, 2017 05:37 PM
fasteddi
Sep 2, 2015 10:29 AM
