ls1 into 86 bird weight loss?
Old Dec 26, 2007 | 04:27 PM
firechicken76's Avatar
Car: 88 Trans am GTA
Engine: 2002 Ls1
Transmission: t-56
Axle/Gears: Ford 9" 4.11 gears w/ locker
how much weight should i lose by swapping in an ls1 t56 into my 86 bird that has a 305 with a t-5 my car currently weighs 3150
Old Dec 27, 2007 | 04:02 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Re: ls1 into 86 bird weight loss?
Assuming your car has an all iron engine, a good 150lbs.
Old Dec 27, 2007 | 04:18 PM
Engine: 2002 Ls1
Transmission: t-56
carb 305, ive also got a fiber glass ram air hood for it, should be worth a little more weight.
Old Dec 27, 2007 | 07:13 PM
Firebat's Avatar
I'm guessing 3025. The T56 is going to be a little heavier than the t5 I would think.
Old Dec 27, 2007 | 08:41 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
the t56 is a pig. the t5 I can carry with one arm. the t56 is like lifting the 700r4 I would guess around a couple hundred
Old Dec 27, 2007 | 08:52 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
I read somewhere that a T56 without bellhousing is 137 pounds. A T5 is between 88 and 92 pounds depending on witch model you have. I can put a T56 in by myself, so that is probably right for the T56 weight.
87v6Bird
Jul 1, 2018 04:12 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
SG91camaro
Sep 5, 2015 10:27 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
