Tried the LT1 Caprice a/c lines...
Old Jan 12, 2008 | 12:46 PM
Firebat's Avatar
Well, someone in an earlier post claimed they made the LT1 caprice a/c lines work with LT1 f-body A/C in a 3rd gen.
I bought used caprice lines and tried to visualize how they could work. The lines would have to bent but thats not the problem. The lines would have to go up through inbetween the rear and middle tubes of the passenger side header. That would make it suck if you ever had to remove the header or engine. Plus, the lines seem like they were too long and seem like they would be in the way of stuff.
Old Jan 23, 2008 | 09:41 PM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
Re: Tried the LT1 Caprice a/c lines...
I'm interested if you come up with something!
Old Jan 24, 2008 | 04:45 PM
socal's Avatar
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
http://www.docsblocks.com/default.asp
http://www.classicautoair.com/
http://www.hotrodair.com/
we got the stock 05 GTO ls2 a/c compressor to work using an adapter block from doc's, but heres a few place's to look
Old Jan 25, 2008 | 08:05 AM
Firebat's Avatar
Thanks socal. I was looking for that hod rod air website.
Old Jan 25, 2008 | 11:53 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
Yep, a while back I posted about hotrod air and the name of the tech that hooked me up with custom blocks, fittings, and hoses made to custom length.. Been so long I can't remember who the tech was but if you search my name you will find it on here. Got nothing but good things to say about how he handled my requests.
Old Jan 26, 2008 | 10:40 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
I tried for two years to get the F body A/C setup to work. I tried F body lines, the carquest adapter and for nothing. The line would have had to go between the header and the head. This is why I went the way I did. I talked with Wayne at Hotrodair. The service was great and he knew exactly what to get me. I posted pics in this post. https://www.thirdgen.org/forums/ltx-...acum-help.html
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
CatmanFS
Sep 19, 2015 09:00 AM
BLK87Z
Sep 18, 2015 11:29 PM
