does a (3800 4thgen) Radiator work the same as a LT1 Radiator???
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: does a (3800 4thgen) Radiator work the same as a LT1 Radiator???
Look at GM's website... see if the part numbers match. I'd be willing to bet they are different.
www.gmpartsdirect.com
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
gm has a different end tank for manual or automatic transmissions, so the part #;s are different. aftermarkets have transmission cooler fittings on all of them. parts store is the same part # if that helps you.
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
A 3800 radiator shouldnt have the steam hose hookup at the filler neck area.
And the core is much much thinner on a 3800
1992 Trans Am
May 10, 2023 07:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
