LT1 383 ISSUES
Old Jan 28, 2008 | 02:15 PM
ssean92's Avatar
Car: sold
LT1 383 ISSUES
Ok guys I am at my wits end, I got the new engine all together and I am having issues with oil not getting up to the heads, I primed it before and got some oil, now I put it in the car and nothing. I started it and heard the horad noise coming form the heads, so I took the V/c off and the heads were dry. so I took the intake back off and primed it with a drill and oil is getting to the lower section of the engine just not coming up to the heads via the lifters. I am running the ls7 lifters, chromoly pushrods, pro mag NSA RR. all that is new, and new oil pump, when I turn it with the drill I am getting oil out of the cam oiling hole, and when I pulled the lifters they are all wet with oil from the center of the engine...... I was wondering should I beable to push in on the lifters?????I cant figuel out what the dral is, am thinking about puting in the old lifters to see if I get oil through them, or will I not be able to get enough pressure to go up the lifter and push rod? I thought I should be able to, and though I remembered it working before
Old Jan 29, 2008 | 01:53 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Re: LT1 383 ISSUES
Are you using a priming tool? Did your engine have all of the oil plugs in it. I have seen engines that wouldn't build pressure because the oil plugs were left out in the front of the engine.
Old Jan 29, 2008 | 02:08 PM
ssean92's Avatar
Car: sold
Re: LT1 383 ISSUES
it is getting oil pressure 60 psi
Old Jan 29, 2008 | 03:10 PM
ssean92's Avatar
Car: sold
Re: LT1 383 ISSUES
it looks like with lifters out that oil is only coming out of the #7 lifter hole
midge54
Dec 27, 2019 04:14 PM
midge54
Aug 29, 2015 09:51 PM
crazynights
Aug 21, 2015 06:53 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
sreZ28
Aug 14, 2015 07:48 PM
