STB w/LT1 in 83 TA not sure what I need
Old Feb 3, 2008 | 11:19 AM
hgffrank's Avatar
Car: 83 Trans Am
Engine: LT1 350
Transmission: 5 Speed manual
Axle/Gears: 3.73 10bolt till it breaks
I am putting an LT1 in my 83 TA at the moment, and the problem is that before I changed directions and went LT1, I had already bought a brand new 3-point Strut tower brace for a carb/tbi setup. Now that I'm going LT1, I dont think this STB will work. So I'm curious about whether an STB for the Tuned Port 350's would clear the LT1 intake.
I'm hoping to find someone that will trade a 3 point TPI STB for my Carb/tbi 3 point STB straight up.
Old Feb 3, 2008 | 11:33 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: STB w/LT1 in 83 TA not sure what I need
the lt1's intake is low enough that i dont think you will have a problem clearing that. The only issues you may have are clearance around accessories
Old Feb 3, 2008 | 11:58 AM
hgffrank's Avatar
Car: 83 Trans Am
Engine: LT1 350
You mean with my carb 3 point or with the tpi 3 point?
Old Feb 3, 2008 | 02:40 PM
Firebat's Avatar
TPI STB will work, in fact its been done before. Can't you wait and find out if the carb stb works once you get the LT1 engine in the bay? Carb stb should work though.
Old Feb 7, 2008 | 11:30 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
The LT1 intake sits much lower than the TPI, so the TPI brace would easily clear the LT1 intake. I'd be very interested in seeing if the Carb brace is high enough to clear the LT1 plenum, but I'm guessing that it won't. Please update us if you have to try it out yourself though.
Old Feb 7, 2008 | 02:28 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
I dont know that a tbi / carb one will clear but the BMR 3 point TPI one does just fine.
Damned word filter, well if you want to see, copy / paste the address and fix the *'s so it matches my username.
Old Feb 11, 2008 | 04:24 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
I found an example of it working!
The username on here is "ssean92" and here is his cardomain page:
http://www.cardomain.com/ride/2076248/2
Biochem
Aftermarket Product Review
Jul 6, 2001 11:10 PM
Stell1579
Feb 1, 2001 10:47 AM
Joe's-88
Nov 26, 2000 09:30 PM
