LS1 in my 88 Formy
Car: 88 formula
Engine: 305 comming soon a 357
Transmission: automatic
LS1 in my 88 Formy
Hello All i am considering putting a 2001 LS1 in my 88 formula. I need some feed back tho...
1.Has anyone done this? and did you use the A/C? i want to do this with everything working.
2.What steering modifactions did you make? did you switch to rack and pinion? new k-member
3.Did you use the stock exhaust manifolds? special headers?
4.Is there any tips that would help?
Transmission: 4L80E/4L80E
Hello.
There's a nifty feature on the Board called "stickies", in the top section of each forum. There is also a subforum for Engine Swap about LTx and LSx, which means that plenty of people have or are doing it.
So, read the sticky, then see if your questions were answered adequately.
Oh, moving this to the subforum.
