T56 HELP
Old Feb 4, 2008 | 06:10 PM
wht96's Avatar
T56 HELP
Does anyone know if there is a differance between a corvette t56 and a camaro one from the same year. i was wondering because i came across a pretty good deal on a 94 corvette t56. ANy help would be great
Old Feb 4, 2008 | 08:16 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: T56 HELP
I believe the C4 T56 are the same as the f-body, just won't have the tailshaft for the torque arm mount (the tailshaft may be different though making it shorter than the f-body one)
Old Feb 4, 2008 | 09:08 PM
wht96's Avatar
Re: T56 HELP
thanks for the reply would anyone happen to know what the differances in the wireing harness is because well i find alot of auto harnesses but a t56 harness is a bit harder to come by any way to convert on auto to manual?
Old Feb 5, 2008 | 12:11 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Re: T56 HELP
Different animal. I'm not sure if all or just most of the C4's used a ZF 6 speed and its not a great trans to use for a swap. They used a bolt on driveshaft so their is no room for a slip yoke like ours and there is less options for clutches. They are tough though be sure of that. They just dont swap in an easily.
Of course you'll want to double check on the fact that its a ZF I cant say for sure. Might want to check over at corvetteforum
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
