Steam tube hook up on LS1 swap
Old Feb 8, 2008 | 07:17 AM
Bradlyj8Z28's Avatar
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
I have read about several choices on where to place the steam tube hose to a nipple in the cooling system. The water pump seems like a popular choice. Is it a simple as drilling a hole in the top of the pump, and getting a nipple to fit the hose and threading it into the hole? Thanks for the help...
Old Mar 4, 2008 | 01:03 PM
Engine: 2002 SS LS1
Re: Steam tube hook up on LS1 swap
Wow, no replies... Well I got a outter and inner threaded brass fitting and it threaded into the small hole on the upper passenger side of my radiator that orginally had a heater hose running to it. Then I found a nipple the same size as my steam tube and ran a hose to that.
If the text in the pic is hard to read, save it and then view it. Thanks, hope this helps somebody...
Last edited by Bradlyj8Z28; Mar 4, 2008 at 01:04 PM. Reason: Automerged Doublepost
Old Mar 5, 2008 | 10:37 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Hey, nice job with that.
I don't recall seeing this thread - but I do remember reading that the EXACT placement of where it goes back into the cooling system isn't critical, as long as it's at the top (or near the top) of the cooling system so that any air pockets that might be trapped in the block can be released.
I'd imagine that you've got nothing to worry about with the way you did it...
Old Mar 6, 2008 | 09:18 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Ahhh the ol' steam tube... LOTS of controversy surrounding this lil feller. Some guys dont even hook it up which is quite foolish IMO. Regardless what you have looks great and I'm sure will work well.
Funny thing... I dont recall seeing this thread before either
Frozer!!!
Jan 19, 2024 04:55 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
IroczFan
Oct 6, 2015 10:13 AM
hayesaw0210
Aug 23, 2015 11:15 PM
reiderz iroc
Aug 13, 2015 04:57 PM
