finally getting started.....
Old Feb 18, 2008 | 09:25 PM
bygblok's Avatar
I've been gathering parts for quite a while now so I can finally start showing progress. My biggest stumbling block to date was the torque arm I had picked up that didn't fit the way I wanted it too. I finally got a UMI piece with the x-member to do the th350 conversion. This is a top-notch piece and I'll be bolting it on to the 9" tomorrow evening.
To date here's what I have;
Built 98 LS1, heads, cam(598/605 comp) doing the carb route with a performer rpm(so I can't spray it too much) Full manual th350 with all TCI internals, BTE 4200 nitrous converter, cheetah shifter, moser 9" with 3.90's, billet spool, 1LE disc brake kit and a pretty well plumbed fuel system using #10 line all the way to the front.
As soon as it's back on the ground in the garage the motor and trans come out and it goes for a tubular front k-member, coil-overs and a manual rack. Then back to me for the motor and trans install..........
It's been frustrating to the point I almost sold my car but I got mad eough to finally go the distance with it. Thanks to all of you guys(especially TJ) for any advise good or bad so far!!
Attached Thumbnails finally getting started.....-camaro-side-rear.jpg   finally getting started.....-crossmember.jpg   finally getting started.....-umi1.jpg
Old Feb 18, 2008 | 09:33 PM
bygblok's Avatar
Re: finally getting started.....
more pics....my bmr extreme anti roll bar and a bad shot of my fuel plumbing out of my tank ..... I'll get a lot more later on.
Attached Thumbnails finally getting started.....-image023-1-.jpg   finally getting started.....-image006-1-.jpg
Old Feb 18, 2008 | 11:31 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Always cool to see other people's projects...
I really like the color on your car, & I'm REALLY liking the color on that swaybar! Sounds like you should have a lot of fun with it once you're done.
One question though - is it going to be a track-only car?? Is that the reason for the TH350? It's just kind of ironic to me, we're doing a very similar swap, but once we're each finished, I'll have twice as many gears to play with...
Anyway, good luck with it, keep the pics coming!
Old Feb 19, 2008 | 04:43 AM
bygblok's Avatar
it will see some limited street use but primarily will be a track car. I would have liked to use the 700r4 but the motor has already made over 400rwhp and add to that another 150 shot of spray and the 700 would probably poop itself. The 6 speed would be FUN and it may one day end up in that direction but for now I'll stay with the 350. Thanks and good luck with yours too!!
Old Feb 22, 2008 | 04:42 PM
bygblok's Avatar
I know that "technically" this isn't LS stuff yet but it's an ongoing project. I got the new torque arm in today and managed to test fit a wheel for fit on the new disc brake setup and check caliper clearance.....for once it FIT!! Here it is with a wheel back on. The long Moroso wheel studs kinda suck but they won't break!
Rocket-Doc
Nov 14, 2015 02:08 PM
Antips16
Oct 30, 2015 06:42 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
