95 impala harness
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
95 impala harness
Will this harness work fine for a lt1 swap in a 85 TA? Or should I find a f-body harness?
Will all 4l60e from impalas,caprice,fleetwoods work in my car?
Car: 1992 camaro
Axle/Gears: 3:73
Re: 95 impala harness
Most of the info on here is for the F-Body so it would be best to have one off a f-body. The tranny will work IIRC just have to change the tail shaft.
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
The Impala/Caprice harness provides a much better fit with the location of the PCM, I use donor Caprice harnesses for my swap harnesses I build typically.
Transmission: 4L80E/4L80E
rs_z28_vert
Sep 30, 2015 09:47 PM
efiguy
Sep 27, 2015 01:30 PM
