LS3 vs LS6
Old Feb 27, 2008 | 10:18 AM
kelham's Avatar
Car: 87 TA / 87 Firebird
Engine: 385 FastBurn / Performance 3.4L
Transmission: TKO600 / 700R4
Axle/Gears: Ford 9" / GM 10bolt
LS3 vs LS6
Looking into a LS swap, I know these engines are available as crate engines, not sure if anyone has ever swapped one into a fbody being them so new. The design is the same as the LS1 so can I use the ls1 parts swap, fuel, kmembers etc. Also am I looking into a custom wiring harness or could I get one from GM
Old Feb 27, 2008 | 03:05 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Re: LS3 vs LS6
The LS3 Was released in the 2008 corvette, while the LS6 was avaliable in the 2001 Z06 Corvette.
There is tonnes of information of the LS6 swap's. Check speartech.com for LS3 swap wiring, Everything else is pretty much the same
Old Feb 28, 2008 | 08:58 AM
kelham's Avatar
Re: LS3 vs LS6
thanks
gixxer92
May 18, 2017 11:20 AM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
Vincent135
Sep 28, 2015 10:50 PM
efiguy
Sep 27, 2015 01:30 PM
