ls1 accessory's throtle body
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
I have seen a couple of people mention using there 3rd gen accesory,s but deciding agenst it. My question is will a serp belt setup from an 89 TB work with a ls1.
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
Re: ls1 accessory's throtle body
no, no, and, no
all sl stuff is just for the ls's and no other way around it
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
Alright that is what I thought but there is nothing that states this that I could find and I wanted to be sure before spending a lot of cash on vette acc. Thanks.
Transmission: 4L80E/4L80E
The majority of people get a full-up drop-out that includes engine, PCM, harness, and accessories, and even transmission, so the sticky didn't cover it. We could add that detail.
The only 3rd gen accessory I recall hearing used is the A/C compressor. And, to do that, you need a custom bracket set-up.
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
Yeh I think that is what I was hearing about too. I was lucky enought to get a 6.0L for free but now I have to piece everything together. And I thought if I could use the accessorys that would be one less thing but oh well. Not that lucky I guess. If you fell like adding it to the sticky it may help someone else I found it hard to search for because all I could get was info on the ls type accessorys. Thanks again.
just make sure the accesoies are for an ls f-body, vett, or gto or they wont clear the hood and you'r going to have to use a pass car style intake,
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
Yeh I am going to buid it up a little while I have it out and have been looking around for a fsat 90 90 setup and still have no idea on what heads and cam I want but I heard a lot of good things about the 6.2l heads with some milling to rase the compresion.
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
