LSx and thirdgen evap/charcoal canister question
Old Mar 15, 2008 | 05:52 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Ok I did a search and saw that a few had said it's possible to use the stock thirdgen style purge canister, but not exactly how.
My question isn't technically for an LSx swap but I am using the same style throttle body. So I am wondering if it is possible, where does the vacuum line connect to? Obviously there's no place on the TB itself, so if anyone has done this how did you go about it?
Old Mar 15, 2008 | 06:00 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Re: LSx and thirdgen evap/charcoal canister question
You may have to "T" off the vacuum line for the power booster or drill and tap the plenum for a new fitting. Drilled and tapped mine for a boostline in front of the driver side runner. Pretty easy.
Old Mar 15, 2008 | 07:37 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Ok adding a fitting to the plenum is no problem as I already need to do that for my HVAC.
I just wasn't sure which type of vacuum source was needed.
Old Mar 15, 2008 | 09:54 PM
Transmission: 4L80E
Doesn't have to be a ported vacuum or anything. Constant is fine. Its regulated by the purge valve
Old Mar 16, 2008 | 11:12 AM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Yeah that makes sense. Didn't really think of that.
Frozer!!!
Jan 19, 2024 04:55 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
