91z28, lt1swap.. wiring to get power to the body harness
Old Mar 28, 2008 | 03:53 PM
91thirdgen's Avatar
i sold my 305 tpi harness and computer, now i am kicking my self, trying to figure out how to get power to my body harness, if any one has done this swap before i could use your help, there is nothing in the ltx swap thread about this, there are 2 conectors from the body harness that went to the old computer and the harness also goes into the c100 conector in the fire wall then to the fuse block.
thanks,
--kyle
Old Mar 28, 2008 | 07:11 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: 91z28, lt1swap.. wiring to get power to the body harness
thanks,
--kyle
My suggestion if you are doing the wiring yourself, get a 90-92 V6 engine harness, that will give you what you need to cut up and make yourself a harness.
Old Mar 28, 2008 | 08:15 PM
91thirdgen's Avatar
do you have a schematic, im sure it cant be more than a few wires running power from constant, and ignition.
i have a lt1 harnes out of a 97 t/a w/ obd1 conversion
and the painless extra long harness
Old Mar 28, 2008 | 08:19 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
http://photobucket.com/ Search for my username, in my album you'll find a pinout of the C100 connector, the power feeds, starter wire, most of the guages, some grounds, and a few other things run through it.
Im sorry you wasted your money.
Old Mar 28, 2008 | 08:20 PM
91thirdgen's Avatar
y is that?
Old Mar 28, 2008 | 08:50 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
y is that?
Because a "painless" engine harness does nothing more for you other than labeling a stock harness, and lightening your wallet a lot in reality.
Vintageracer
Jan 10, 2020 05:33 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Caspar
Jun 19, 2016 11:19 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
stalkier
Aug 13, 2015 12:59 PM
