Another LS1 into a 3rdgen.
Old Apr 3, 2008 | 08:54 PM
HiPerf_Chevyman's Avatar
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
I'll Be doing this For sure! Just got a few questions So I can start Shopping.
Whats with the Motor Mounts? everyone has Diffrent Setups. How Come?
And What Wires Have to Be Spliced? Stuff for the Body? Such as Tail lights/headlights?
Old Apr 3, 2008 | 09:52 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Re: Another LS1 into a 3rdgen.
For motor mounts, ive tried almost every setup. The spohn ones work the best.
S&P style ones will cause you nothin but headaches.
Old Apr 3, 2008 | 10:06 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Got my spohn k-member and mounts on order. I'll send some pics when i get them.
Old Apr 3, 2008 | 10:52 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Grmph. I did NOT want to hear that...
Ah well, if it's a problem, I'll just deal with it...
Old Apr 4, 2008 | 12:11 AM
Car: 1991 Camaro RS
Alright, Got that on the list.
Im Not much of an Electrical guy... I can do it. but takes me some time. I dont care about what wires Specifically.. just a few would give me an ideal.. I have access to alldata.. and I can get some Wiring digrams while Im here. but once i get home and do this swap.. I wont have such access.
Old Apr 4, 2008 | 06:46 AM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
The one design that essentially puts the thirdgen mounts on the front of the LS1 mount (i put up pictures of that) positions the motor too far forward.
Im just finishing up a 2nd set of mounts that are teh same idea but push the motor back 1". Ill hopefully finish them for tonight and get some pictures up of how it mounts before i end up just using my straps & plates i made.
BTW: If anyone need's mounts fabricated, ive got 1 set of 6061 Aluminum S&P style, and can also make spohn type mounts.
Old Apr 4, 2008 | 08:26 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Read this carefully
https://www.thirdgen.org/forums/ltx-...want-swap.html
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
