Ls1 Auto Y Pipe Pics
Old Apr 3, 2008 | 10:40 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
Im at the last step of doing the exhaust on my swap and want to see what the auto swappers have come up with. There is not much room there and most everyone on here has the T56s.
Post Pics!
Old Apr 4, 2008 | 08:31 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Re: Ls1 Auto Y Pipe Pics
I too want to see what if anything has been done. We need auto y-pipe links for the sticky which I am going to update soon. Good luck
Old Apr 4, 2008 | 02:44 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Ill never go auto... but being the curious guy that I am, Ide like to see what people came up with too. The y-pipe, in my humble opinion, is the most challenging part of the LS1 swap. Even for the t56 guys if you want it to look good and flow good... Simply because there is no good aftermarket solution.
I dont know the undersides of the auto cars very well...but I remember them being TIGHT.
J.
Old Apr 4, 2008 | 02:59 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
J.
Yup VERY tight. I would probably do a frame sectioning/re-work if I ran an auto with an LS1 ( or any engine with LT's for that matter ) which is why I'm curious to see if anyone chimes in here. In fact I cant stand the entire floor pan layout of third gens it really is their achilles heel. I'd probably chop out everything from the rear seat to the firewall and make it all new. It wouldn't be very difficult at all with some 2x3" rectangular tube and some 20 gauge sheet metal. All migged up solid and strong it would make room for the exhaust and act as a body stiffener/frame connectors and incorporate a torque arm mount.
Otherwise there is little choice other than running underneath the trans cross member which is less than great for ground clearance. It works though I;ve done it in the past on auto cars.
Old Apr 4, 2008 | 08:40 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
about the best ground clearance you could ask for with a spohn x member.
the pipes have been ovaled out a touch(rednick engineering)
its low, but i dont scrape on speed bumps.
3" y
4" I with a bullet muffler
Old Apr 4, 2008 | 09:17 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Axle/Gears: 4.11s
i only briefly looked under the car.. i know the pipe for the 6 speed and ls1 with the drews wasnt easy for anywhere I took it as we are limited to people that can do quality work
this time if its wrong I can only blame my friend that will be helpin to weld it up
I thought about tryin to go around the frame and a crossover over the bottom of the tranny.. we'll see next weekend
Old Apr 5, 2008 | 07:09 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Great thanks Stage 20 do you have more pics? From the side and perhaps some that might show the y-pipe design better? We'll add this thread to the sticky
Old Apr 5, 2008 | 11:00 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
only other one i have. the 1st piece of pipe is 2.5" to fit the stainless works collector. it was actually a 4ft piece of pipe with a lil bend in it and chopped it down to about 6" so we could clear the spohn x member. it was the only way to get a good bend around the tubing.
i have plans to switch styles of torque arms as soon as i come across a deal.
what i have works, i dont want to buy a new one.
Old Apr 5, 2008 | 11:15 AM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
I'd also like to see some pictures of what people did for y-pipes using the stock manifolds. Should my local exhuast shop have the flanges to mate up to the ls1 manifolds?
Old Apr 5, 2008 | 12:33 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Axle/Gears: 4.11s
i got the flanges from:
http://www.stainlessworks.net/cart/index.php
im running without longtubes so Im hoppin to find a way to get it tucked better
Old Apr 5, 2008 | 09:26 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
here is a lil better pic of the y pipe
Old Apr 7, 2008 | 09:28 AM
Car: 86 Trans AM
Yikes...that does not look fun gents. Almost makes me glad to deal with my master cylinder issues... haha. I ALMOST went auto. The deal for my donor car was too good to pass up, and it was T56 so thats what I got. Its proving to be more fun for me anyway. haha.
The pipes pictured dont look too bad. As long as you arent beating them up on the street they look good!
J.
Frozer!!!
Jan 19, 2024 04:55 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
lt1z350
Aug 28, 2015 05:57 AM
