LQ4 Th350 Do I still need Spacer?
Old May 1, 2008 | 11:17 PM
We'reNotWorthy's Avatar
Well Im getting ready to pick my Lq4 soon and Im kinda starting to want to keep the Th350. So I have been looking around and I foundthe whole spacer thing but then I checked TCI. They have a flewplate for th350 to ls based motors. I'll put up the link with the table and the link for just the ls th350.
Table is halfway down the page.
http://tciauto.com/Products/GM/gm_tu...amatic_350.asp
Heres the actual flywheel.
http://www.compperformancegroupstore...ct_Code=399753
Old May 3, 2008 | 01:29 PM
Re: LQ4 Th350 Do I still need Spacer?
Come on someone has to know this.
Old May 3, 2008 | 01:37 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
you will need the spacer unless you have a converter designed to fit the th350, with the long hub for the ls1 crank.
the short hub on a std sbc converter isnt long enough to mate up with the crank on the lsx motor.
if you got the lq4 from a 2500-3500 it should already have the spacer on there.
you can use the stock flywheel from a 2500-3500 series trucks for a th350 as well.
Old May 3, 2008 | 03:52 PM
Will I be able to change to a T56 later down the road if I want or will the spacer cause huge headahces because I had orginakly planned to use a 4l60e. THat was thrown out because of the power I'll be layin down.
Old May 3, 2008 | 04:38 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
The early Lq4's have a thicker flange than the lq9/ls1's. You won't need a spacer if you have that year. You will have to elongate the bolt holes on your fly wheel to bolt to the tq converter. As far as a t56... you'll have problems there cause the thicker flange.
Old May 4, 2008 | 01:09 AM
socal's Avatar
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
sorry to hijack but i heard about this and was wondering about a t56 to my 99 5.3 or 00 4.8 will there be a problem i have both motors and am planing to use the 5.3 in my swap but if some one knows better chime in thanks
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
