few lt1 questions
Old May 4, 2008 | 02:41 PM
iroc1793's Avatar
Car: 1987 Camaro Iroc-z
Engine: 305 tpi
Transmission: t5
few lt1 questions
School is winding down and i am getting closer to starting my lt1 swap. I have a few questions
1.) i would like to replace the motor/tranny mounts, i believe i have read that the lt1 mounts will work with the third gen mounts, so when buying new does it matter if i get the ones that are stock for my 85 iroc or for the 94 lt1
2.) i have a cold air intake that came with the donor car for the swap will it work with my iroc
3.) will the iroc radiator and fan work fine with the lt1
thanks in advance for all the help!
dan
Old May 4, 2008 | 03:00 PM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
Re: few lt1 questions
1.) use the mounts for your 85 just get some good poly replacements
2.) you may have to do a little cutting but you can probably get it to work
3.) stock radiator will work you need the upper hose from the lt1 and everyone says use a corvett lower hose but i just cut a few inches off the end of my stock hose and it fits fine. these motors like to run a little warm so you will need to get a good dual fan setup the lt1 and ls1 fans drop in with little modding and are cheap and easy to find.
Old May 4, 2008 | 03:16 PM
iroc1793's Avatar
Engine: 305 tpi
Transmission: t5
gapimpin: thanks for the help, i have the fans from the 94 camaro, so i will use those, thanks again
Old May 5, 2008 | 03:42 PM
iroc1793's Avatar
Engine: 305 tpi
Transmission: t5
i forgot to ask one question, im installing long tubes aswell, and was wondering if it would be easier to put the headers on the engine first then drop it in as one unit or put the engine in then the headers after.
thanks
Old May 6, 2008 | 04:37 PM
gapimpin's Avatar
Engine: 383 LT1
not sure i know of any long tubes that can be dropped in with the motor... i know for a fact if you have hedmans they can not be... that was a bad 45min trying... best way i have found if you have headers that fit tightly is to put them in place laying on the fender wells then drop the motor in. your gonna need to move them a few times so it helps to have a friend there... just keeps you from having to pull the motor back off the mounts to drop them in after.
Old May 6, 2008 | 09:45 PM
iroc1793's Avatar
Engine: 305 tpi
Transmission: t5
thanks again for the response, im trying to get all my unanswered questions answerd, trying to make it as easy as possible
Old Jul 3, 2008 | 02:35 PM
RaGe's Avatar
Car: 1990 Firebird Formula
I made hedman longtubes work with my car. It did take more than 45 minutes. I had to clearance the a-arm bracket a bit and dent one of the primary tubes. I should have worked the k-member more as I still have some vibrations at idle.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
87iroctheo
Dec 4, 2016 11:47 AM
midge54
Aug 29, 2015 09:51 PM
redmaroz
Aug 16, 2015 11:40 PM
